Ae92 levin front end conversion!
Posted: Thu Jun 27, 2013 3:01 am
by Kayjayyaah
I have some questions about the conversion! Pleasee help me out, email me!
Kayjayyaah@gmail.com
Re: Ae92 levin front end conversion!
Posted: Fri Jun 28, 2013 2:49 am
by Blof-fan
It would be easier to just post the questions so we could try to answer them
Posted: Fri Jun 28, 2013 5:57 pm
by Kayjayyaah
I just picked up the jdm levin front end and i was wondering do i need the jdm radiator support because i noticed the jdm bumper brackets dont slide into the support. Is there any cutting and/or welding involved in doing the conversion or is it straight bolt on? Any help is appreciated
Posted: Sat Jun 29, 2013 1:24 am
by Toyoloog
I guess you're changing from USDM to JDM? There are some differences because of the impact bar. On which car are you trying to install the Levin front?
Posted: Sat Jun 29, 2013 4:20 am
by Kayjayyaah
Ae92 91 toyota corolla coupe
Posted: Sun Jun 30, 2013 1:06 am
by Toyoloog
Market / chassis code?
Posted: Sun Jun 30, 2013 9:20 am
by Blof-fan
Since you said your brackets are not sliding in the supports, my guess is you have a USDM car right?
You probably have little plates blocking the brackets from sliding further down?
Easy fix: remove the little plates. Just drill out the spotwelds (mind you, there are quite bit of them for such a small plate) of the plate and it comes right out
I had the same thing on my USDM car which I wanted to convert to a JDM front bumper.
The holes for the bolt of the new brackets are already there, so after removing the plates it's pretty much plug and play:
All the other things like the hood, headlights, fenders, etc, etc should be pretty much bolt on
Posted: Sun Jun 30, 2013 1:25 pm
by Kayjayyaah
Niice! Thanks! I was wondering is the bulb size the same for the levin? So can the hid i have on my car for the flip up same as the levin headlights??
Posted: Sun Jun 30, 2013 1:52 pm
by Blof-fan
As far as I know, they're al H4 bulbs. So shouldn't be a problem I guess
Posted: Mon Jul 01, 2013 1:14 am
by Kayjayyaah
How do you adjust the levin headlights? One of them r aiming higher than the other. Thanks again'
Posted: Mon Jul 01, 2013 7:38 am
by Blof-fan
There should be 'long' bolts or srews on the back of the housing. With those you can ajust the reflector behind the bulb and adjust your lightbeam.
Be carefull though, a lot of them gathered some rust over the years and might not turn so easily anymore...
Posted: Mon Jul 01, 2013 2:31 pm
by Kayjayyaah
Fasho! Thanks ill wait till it gets dark! Do you just twist the bolt?
Posted: Mon Jul 01, 2013 11:16 pm
by Kayjayyaah
How do you wire up the foglights on the levin headlights?
Posted: Tue Jul 02, 2013 1:02 am
by Blof-fan
That I don't know
But forumuser Toyoloog might just be able to answer that question for you
Posted: Tue Jul 02, 2013 3:28 pm
by Kayjayyaah
Does anyone know what the bulb size is for the foglights? & where to buy them from?
Posted: Wed Jul 17, 2013 3:11 am
by ariyan
Kayjayyaah wrote:Niice! Thanks! I was wondering is the bulb size the same for the levin? So can the hid i have on my car for the flip up same as the levin headlights??
yes of course you can use levin headlights because levin headlight can be changed to also make your car more appealing.The European version Corolla Levin 1600 GT Liftback (AE86).
Posted: Tue Aug 06, 2013 2:02 am
by Toyoloog
Kayjayyaah wrote:Does anyone know what the bulb size is for the foglights? & where to buy them from?
Standard foglight use H3 bulbs in eigther 55 of 35 Watt's
