40mm rod bearings question
Rogue-AE95
Postby Rogue-AE95 » Sun Oct 10, 2021 8:31 am
I'm posting this here because it's something relating to the 4A-FE and the early 4A-GE. Both gens of 4A-FE rods and of course early bigport GE rods have 40mm big ends. But the bearing part numbers are different. Any ideas why that is?
Mark 1 bearings used as examples.
4A-FE:
13041-15030-01 (superseded by 13041-15031-01)
4A-GE:
13041-16040-01
Is it something about the GE bearings being for higher RPM / "race use?" Are the rod IDs slightly different? Rod widths are different?
Re: 40mm rod bearings question
Postby oldeskewltoy » Fri Nov 05, 2021 8:47 am
buy a set of each and tell us............
davew7
Postby davew7 » Sat Nov 06, 2021 5:23 am
If you visit the Mahle/clevite web site, they indicate the same P/N CB1361P bearing for both motors.
Rogue-AE95
Postby Rogue-AE95 » Mon Nov 08, 2021 5:43 pm
Thanks Dave. It's odd that Toyota changed the part number if the parts themselves did not change.
davew7
Postby davew7 » Tue Nov 09, 2021 4:37 am
It is common for OEM,s to change part numbers when they change suppliers, just for tracking/tracing. We will possibly never know why the P/N change.
