manual rack
elnitro
manual rack
Postby elnitro » Thu Dec 17, 2020 5:33 am
hi guys i would like to know if the ae92 come with manual rack from factory and what year.thanks
11.9 @ 115 mph
Rogue-AE95
Re: manual rack
Postby Rogue-AE95 » Fri Dec 18, 2020 8:29 pm
Base models did, at least for sedans. I have one that I pulled from a 1989 Geo Prizm. It's more turns lock to lock than a PS rack, but I like having less to maintain or be in the way in the engine bay.
elnitro
Re: manual rack
Postby elnitro » Tue Dec 22, 2020 3:58 am
do you know what other parts are need to this swap.
11.9 @ 115 mph
Rogue-AE95
Re: manual rack
Postby Rogue-AE95 » Tue Dec 22, 2020 5:51 pm
Yes, you will need:
• manual rack
• brackets & bushings x2
• firewall shroud x2
• steering column (all I've found are non-tilt) **
• knuckles are supposed to be different, I have a set but never compared them to my PS knuckles
** If you have a tilt column with power steering, you will need to extend the splined end of the shaft that comes after the U-joint. I had a friend help me by cutting the shaft, then welding in a piece of round stock so that the PS column would reach the manual rack.
Here's a topic I posted years ago on the All-Trac wagon forum. The pics are still there, but have the Photobucket watermark now.
http://forum.alltracwagon.com/cgi-bin/f ... 44180/s-0/
For my AE95 wagon, I had to drop the subframe in order to get at one of the rack brackets. It was a headache. FWD may be different.
elnitro
Re: manual rack
Postby elnitro » Wed Dec 23, 2020 2:14 am
ok thanks.
11.9 @ 115 mph
