Cleaning up AE92 Engine Bay
Posted: Wed Feb 20, 2013 9:56 am
by chitownae92
So I really want to clean up my AE92 Engine bay, does anyone have any suggestions as what I can possibly remove to make it look cleaner, does anyone have any pics, I'm currently running a MAP 4AGZE but its AFM because I didn't have what was needed to have it MAP. I've moved battery to trunk so that made a little cleaner but I want to remove more and clean it up a bit, any help is greatly appreciated.
Thank You
Re: Cleaning up AE92 Engine Bay
Posted: Wed Feb 20, 2013 12:50 pm
by Toyoloog
I've got a windscreen/headlight cleaner reservoir from an Swedish AE92 which is mounted under the fender. (because the "normal" space is occupied by the ABS pump)
You can remove the battery bracket if you already removed the battery itself.
Posted: Sun Feb 24, 2013 9:31 am
by ga_goosh
you can get a high comp spark plug valley cover to hide/clean up the top of the motor. you can also get the distributor boot from an aw11 to cover up the cap and wires for a cleaner look.
Posted: Tue Apr 16, 2013 3:17 am
by foyejstuart
Well, it is hard to say that how to clean up the engine bay. I am also getting bored during cleaning engine but what to do, i have no idea on it. If anyone has proper idea, than share it..
Posted: Tue May 07, 2013 9:15 pm
by asjoseph
