1ZZFE COP Conversion
SlidewayzAE86
Postby SlidewayzAE86 » Mon Mar 20, 2017 11:55 am
Just wondering if I could get more details on this setup...
I'm running megasquirt 2 3.57 on AE92 4AGZE...
Was curious if anyone had experience with this setup...
And also wondering if anyone has a set for sale..
aukword1
Re: 1ZZFE COP Conversion
Postby aukword1 » Mon Mar 20, 2017 4:09 pm
I am doing this conversion in the very near future. I ordered the blanking plate from SQ-Engineering. They also have some very helpful articles on their website. Basically they have four pins, one pin goes to ground, one pin to ignition on power source and another to the ECU. One pin is for some sort of sensor that is not needed. You have to setup the megasquirt to send the signal to the coilpacks. I have the PNP version so its a lot easier for me but I am sure it can't be too hard. Megasquirt 2 and 3 are both compatible with doing this conversion.
SlidewayzAE86
Postby SlidewayzAE86 » Tue Mar 21, 2017 9:34 pm
Awesome ok thanks...I got the 1ZZFE coils yesterday and I'm gonna install them Thursday....I'll keep you updated and let you know
aukword1
Postby aukword1 » Thu Mar 23, 2017 8:30 am
Awesome, good luck to you. Here are some articles that I found to be useful for the swap..
http://www.86garage.com/forums/viewtopic.php?p=10869
http://www.sq-engineering.com/tech-arti ... info-guide
http://www.msextra.com/forums/viewtopic ... 16&start=0
Just in case you get stuck. :)
SlidewayzAE86
Postby SlidewayzAE86 » Thu Mar 23, 2017 8:45 am
Ok thank you...I appreciate the help :)
SlidewayzAE86
Postby SlidewayzAE86 » Thu Mar 23, 2017 1:57 pm
Boom...started right up first time lol...runs better actually. Still running rich though but I'm gonna start tuning it to get better. No plug wires and no coils cleans up the bay alot too lol
aukword1
Postby aukword1 » Fri Mar 24, 2017 7:28 am
very nice man, congratz on the new mod ;)
SlidewayzAE86
Postby SlidewayzAE86 » Fri Mar 24, 2017 7:40 am
It was so much easier than I thought too...since the megasquirt had 2 spark outputs, just wired 1and4 to spark A and 2and3 to Spark B....NO ecu setting change at all. Now it's time to clean up the wiring and get the plate done for the coils :) thx again for the support and advice....I do appreciate it :)
aukword1
Postby aukword1 » Fri Mar 24, 2017 8:06 am
No Problem, can't wait to do it myself. Just waiting on the blanking plate for the distributor, have everything else already. Glad everything worked out easy for you.
