TE72 brake question
raviolikid134
TE72 brake question
Postby raviolikid134 » Wed Apr 30, 2014 12:58 am
Im converting my TE72 wagon to run ae86 front brakes. I'm wondering if I can run ae86 braided steel brake lines as well. Anyone have any insight?
raviolikid134
Re: TE72 brake question
Postby raviolikid134 » Fri May 02, 2014 1:35 am
Any body out there?
OGrolla
Postby OGrolla » Sat Jun 07, 2014 11:00 am
yes you should be able to, I'm even putting rx-7 brakes on my E7 and im going to use ae86 SS lines
Postby oldeskewltoy » Sat Jun 07, 2014 12:20 pm
raviolikid134 wrote:Im converting my TE72 wagon to run ae86 front brakes. I'm wondering if I can run ae86 braided steel brake lines as well. Anyone have any insight?
yes... but that is NOT going to be your problem....
The E7 chassis is 12mm wider @ the strut mounts then an AE86. This means installing AE86 struts will automatically give you 6mm postive camber per side.
To "fix" the positive camber... you'll either need adjustable upper strut mounts, or longer (adjustable?) low control arms.
