I've got a superstrut suspension setup for anyone interested in swapping. This bolts in place of your Mac Struts, but has better geometry more like a double wishbone. If you rear lower control arm bolt is vertical (some AE101, all ZZE110, possibly the E120 as well, newer Celica I think) this will bolt right in. If not, 2 of the big bolts on its k member do line up with the AE92 chassis and the rest can be fabricated. I put it in the FS section with suspension, but it was the only suspension post in there. It's now buried in wheel posts. This is coilovers, control arms, k member, knuckles, calipers, rotors, the works!
viewtopic.php?f=20&t=9930
