TE72 T50 Tranny Swap???
I have a 1980 Te72 5 speed coupe and the tranny went out and i was wondering if the t50 from an ae86 would work?? or if i need anything else to make sure they mate? any help would work thanks.
1986 Sr5>Gtsr5(Soon) Hatch DD.....![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: TE72 T50 Tranny Swap???
the trans will work just put your bell from your old trans onto the new trans and it should work. you might have to reuse your shifter but im not sure also you might have to swap the tail section but again im not too sure just compare them when you have them next to each other
ga_goosh wrote:the trans will work just put your bell from your old trans onto the new trans and it should work. you might have to reuse your shifter but im not sure also you might have to swap the tail section but again im not too sure just compare them when you have them next to each other
awesome thanks i will check them out side by side. thanks
