Door jamb seat belt retractor thingy, what does it do?
The part circled in red - what exactly is it supposed to do? Seems to have something to do with slowing the retraction of the seat belt when you close the door? Kind of annoying since the seat belts hardly retracts by itself. Anyone?
Re: Door jamb seat belt retractor thingy, what does it do?
Once depressed, with the door closed, it allows it to lock when yanked on. As is stopping short or an accident, the the belt holds you in place. When the doors open, you can yank on the belt and it wont lock up.
My turd of an 86
20v swapped 86 write-up
My turd of an 86
Here's a write up about fixing your sagging seatbelts.
http://forums.club4ag.com/zerothread?id=41464
That doesnt cover cleaning the inside stuff, which helps it retract. I have something somewhere about that...
A few posts down, here
http://forums.club4ag.com/zerothread?id=18877&page=14
My turd of an 86
My turd of an 86
Yikes, that's kind of important
OK, thanks guys
morgan wrote:That doesnt cover cleaning the inside stuff, which helps it retract. I have something somewhere about that...
Oh nice, I knew I read that before, but I didn't know it was in your old build thread. Did you notice a big difference with the belt retracting after?
I tried the first method with minimal success, my balls didnt look too dirty so I didnt clean them ):
cliqwe wrote:I tried the first method with minimal success, my balls didnt look too dirty so I didnt clean them ):
You should always clean your balls. Always.
Thanks for that other DIY. I had the first one bookmarked to use down the road. Bookmarked this second one for future reference as well.
If your seatbelts are slow to retract, try spraying the inside of the
belt with a dry silicone aerosol. Spray the length of belt that slides
over/thru the top hanger on the door pillar. The spray is non-marking
so it won't get on your clothes. Worked for me
Ironing the belt while it's out might also help.
Somebody in another thread had a good idea of putting some type of teflon/ptfe tape on the surface of the hanger that the belt passes over, but I haven't been able to find anything for a reasonable price to try.
