93 SC400 lighting woes
carbd7age
Postby carbd7age » Sun Jan 26, 2014 4:44 pm
K gang, I have an annoying problem. The rear turn signals on my SC don't function properly. On a zenki SC there are 3 1157 bulbs across the yellow lens in the tailight. Well if I have all 3 bulbs in there, they won't light up instead the brake lights under me come on. If I run just 1 bulb, it works but blinks fast because there are two missing. I left the hazards on to test. The one bulb os bright, add a second or third and the filament only barely glows a touch.
I think the issue is something to do with series vs parallel but my electrics smarts are rusty. :oops:
The other issue is the rear light warning light is always on, but the 3rd brake light is missing so I will replace that and that should be fixed.
Knockoff Crew member #0001
williamdavis22915
Re: 93 SC400 lighting woes
Postby williamdavis22915 » Sun Jan 15, 2017 3:45 pm
Sounds like a bad connection or ground
1985 gts hatch
Return to “TECH: Inline 6's and V8's (JZ, G, UZ etc...) and Big Sedans”
