FRS BRZ harness bar
vrtkevin
FRS BRZ harness bar
Postby vrtkevin » Sun Aug 25, 2013 8:38 pm
Listing a new in box Harness Bar from Essex. We don't have a FRS we have a AE86 so it won't work. Brand new in box with all info. Sells normal for 649. I am asking 450. Save 200 on me. Pick up preferred but can ship if needed.
Kevin
http://ft86speedfactory.com/essex-ft86- ... 4e0db55cff
Here is all the info if you want to read.
Details:
Essex has created what we feel is the ultimate harness bar for the Scion FR-S and Subaru BRZ. While our bar is definitely attractive, our goal was not to create a, style bar. Our design objectives were focused almost exclusively on function. We wanted to make the stiffest, lightest, and most versatile bar possible, and we believe we have succeeded.
No modifications to the OE sheet metal are required- All of the pieces in our harness bar kit bolt to existing holes in the car. There is no cutting or modifying required. Our bar can be seamlessly and completely removed to put the car back to stock condition.
Retains OEM front seat belt mounting points- Our bar can be installed while keeping the front seat belts functioning as intended. Also, the OEM shoulder belt mounting location does not change. We simply provide a longer bolt, and the factory belt rests on top of the plate for our harness bar. Both OEM seats slide all the way back and recline comfortably with bar installed.
1-3/4in O.D. x 0.095in wall thickness steel tube for maximum rigidity- Our bar is a single piece that extends from B-pillar to B-pillar. There are no mid-tube connections, as mid-tube connections are typically not as rigid. While we're not making any claims with respect to chassis stiffening, we will note that the load paths through our assembly are in a straight line. This does increase stiffness more than a design that follows a tortuously crooked or curved path.
Adjustable height with 4 positions- The four positions allow for a wide range of vertical adjustment. We've provided an appropriate mounting point for drivers of different heights, and for those running various types of seats and mounting methods.
Four primary attachment points to the chassis- All four primary connection points are directly to factory belt mounting locations, and there are no flimsy sheet metal connections. Our bar has billet aluminum end plates that attach to both B-Pillars. The end plates are bolted to the factory shoulder seatbelt mounting points (near the roof, behind your head). A tension rod attaches at the bottom of each plate and runs back to the shoulder belt mounting location for the rear seat. Having multiple mounting points securely locks the bar to the chassis, and the tension rods have left and right-hand threads allowing infinitesimal length adjustments to simplify fitment.
Mounting plates are machined from ½” billet aluminum plate- Light, precise, and strong, our low-profile machined billet aluminum end plates allow the bar to be accurately positioned in the car without intruding into the cabin. Only one small piece of interior plastic must remain out of the car when the bar is run in the default top position (the piece closest to the top OEM shoulder belt mount).
Durable and attractive black powder coat finish- All of our components are powder coated semi-gloss black. When the bar is installed, it does not attract any unnecessary attention, and it blends nicely with the interior of the car.
Only the bar itself and a small portion of the billet aluminum end plates remain visible.
Highest quality fasteners- Only high-strength fasteners are employed. Weight with fasteners is 14.5 lbs.
vrtkevin
Re: FRS BRZ harness bar
Postby vrtkevin » Wed Dec 18, 2013 8:59 pm
price lowered to 275 as I feeling the xmas spirit and just don't need it. Its brand new just pulled out to look at it.
Return to “FT86 (Scion FR-S / Toyota 86 / Subaru BRZ) Parts & Accessories”
