I know a lot of you don't care for stories other then pictures and valuable info so I'll just get straight to the point. I will only elaborate on a section I feel it maybe important.
You can do this set up using the 4k dizzy but I'm going with a different route.
Webers fuel delivery: No more then 4 psi
Mikuni fuel deliver: no more then 3.5 psi
Just showing you a SR5 harness with a Proactive 6 Ignition box & 4k Dizzy Startlet that had been modified w/4age dizzy to work with carb conversion but I dumped the dizzy & ignition box. I just needed the SR5 harness because I didn't want to chop up my GTS harness. You'll need a tach Adapter which is shown in this picture!
40MM Mikuni Solex
Kameari manifold
small port studs and small port bolts for intake. I did 5 studs & 4 bolts.
16mm freeze plugs to plug up your injector ports OR you can now buy injector port plugs from Technotoytunning for $25.00
Holley FPR # 12-804
Or you can go with a Malpassi FPR
High pressure low volume carter fuel pump # GP4070 6psi AND you won't need no more then 4 to feed your carbs. and you can measure it through your FPR
If you are wondering, "why not I just use my stock fuel pump and have it regulate by a *return style* FPR (Aeromotive # 13301)" It should work right!? Heck no! It will spike SO bad your fuel gauge just get crazy! You'll just end up causing damage and giving you a inaccurate fuel reading.
Aeromotive fuel gauge
Innovation MTX-L #3844 (comes with harness kit, two face gauge (blake and white), bung (it's not shown in picture. I welded the bung to the test pipe) and gauge.
these are wires coming off from the innovation gauge
A vacuum reservoir I purchased from summitracing. You might noticed a change in your brake pedal.. Feels like a rock is behind the brake pedal and will not press all the way down because with the carbs it may not supply enough vacuum to the brake booster. With this, it will store and create more vacuum for you so you won't have to buy a $300 vacuum pump.
just showing you how BIG the vacuum reservoir is
MSD 6AL2 #6530
Dr. Orcca had posted a while back that you'll need the msd 6al and a msd timing ignition curve (#8981), those old part numbers are no good and had superseded to a new number. The timing ignition curve is not available anymore and is discontinued. Your best option is the 6AL2, a digital programmable! Hook it to your computer to map out your timing curve and set up your base map. There are lot of settings to this as I will get into more details about this.
I didn't want to mount this in the engine bay (which a lot of people will do) so I mounted on the passenger floor side. Trying to keep it away from heat.
Here is a wire diagram on how to wire up the MSD BOX and Tach Adapter. This isn't mine but from a member.
These are all the parts I needed to get the carb conversion set up going. You'll noticed after you had pulled out your GTS harness, you had also pulled out your wiper motor wires. I'll show you how to wire that up. Simply trace down the wiper plug & wires, you want to separate that out of your GTS harness. Using a pick, carefully removing the unwanted terminals and only keeping what you need on the wiper plug.
this is what it should look like after you had removed the unwanted terminals & wires
plug it back up to the junction block on the passenger side. Now your wipers work!
Now for the location of the fuel pump and plumbing.
You'll notice a lot of people will install the fuel pump up in the engine bay. NOT a good idea. You will only shorten the life of your fuel pump by doing that. A fuel pump is designed to PUSH fuel, not pulling fuel. Mount it near the fuel tank. If you can, mount it to where it is almost leveled with the tank.
Here's where I mounted mine. The right rear quarter. I know, you're thinking if I get hit there, I'm F$%*!!! Well, I don't intend to get hit there... *crossing fingers*
Here is a vague picture of fuel plumbing. Fuel will need to be in this order: tank>filter>fuel pump>filter>carbs
I'm running 268/268 crower cams w/adjustable cam gears.
My jettings are:
Pilot air-57..5
Air-180
Fuel-140
Accelerator pumps-40
Idle mixture screws.... I can't remember how much turns I did... sorry...
Here how it is
http://www.youtube.com/watch?v=iTmnqIQ7AWI
http://www.youtube.com/watch?v=G1eoFzWIz8c
