Problems with low beam switch - And, how to reattach signal stalk properly?
Ava92
Postby Ava92 » Wed Oct 17, 2018 8:19 pm
Hey all
I put in LED sealed beams about 1 year ago. Been dailying it without issue until now, the Low-beam stopped working only on one side.
I swapped the bulbs and problem persisted (same side), so it's not the bulbs.
1. I read online it could be either the signal stalk, or the white dial switch. Removed my white dial, took it apart, and all my circuit board and wire connections look fine. Should I just blob some solder on each point to be safe?
2. While tinkering, I stupidly removed the 2 golden screws holding in the signal stalk spring. I now have no clue how to reattach it properly? The stalk wants to "push" itself forward all the time now (highbeam). With the slightest pressure it pops into highbeam mode (forward)...is there a certain way to put the spring back so it work like OEM? It felt 100% fine before. Tried reattaching it for an hour straight. I only detached the little silver cover that holds the spring inside the gold cylinder. Is the spring supposed to sit naked against the silver part? did i lose some tiny piece somewhere? searched my floor and didn't see anything
Thanks for taking the time to look at my post. I do have a test light if needed
Re: Problems with low beam switch - And, how to reattach signal stalk properly?
Postby jondee86 » Sun Oct 21, 2018 2:38 am
You were messing with this thing... ?
This page from the AE86 Body Manual has a mention of installing the lever...
Apparently there is a ball involved and a specific way for assembling the arm
to the switch. But I have never played with one so I can't give you any advice.
UNLIMITED 86
Postby UNLIMITED 86 » Sun Oct 21, 2018 1:48 pm
Yes. The problem sounds like the ball detent isn't working properly. One of the pieces (ball or spring) probably fell out without you noticing. Works kind of like a retractable pen.
Take it apart again and look carefully. Due to age, you should see the wear marks where the ball (or spring thats usually behind it) once lived.
Make Club4AG Great Again!
Ava92
Postby Ava92 » Mon Oct 22, 2018 11:54 am
Yea that's the thing
I have the spring but no ball! I'll keep lookin around for it
I have it reassembled and it "works", but doesn't feel OEM-smooth - it sort of grinds when I push it into highbeam
Still haven't fixed the low beam problem either, I guess it must be wiring somewhere since the switch looks fine and the bulbs are ok
I appreciate the help especially the page
UNLIMITED 86
Postby UNLIMITED 86 » Mon Oct 22, 2018 3:52 pm
Any ball that fits will work. Sounds like the original is a lost cause. Take an old ball bearing apart or use a BB (as in BB gun?), they come in different sizes.
I recently had the same issue with my left side headlight. I thought it was the bulb so I bought a replacement. Decided to wait until I finished my swap to install the new bulb but once I got it running, the light was working again.
While doing the swap, I did notice a few wires going to my under hood fuse box had seen better days so I fixed them. Looking back, i probably fixed my headlight without knowing kt. You might want to look there.
Users browsing this forum: No registered users and 22 guests
