notnilc20's Ongoing For Sale Thread.
notnilc20
Postby notnilc20 » Mon Jan 09, 2017 1:18 am
I'm going to start my for sale thread and just keep updating this thread with new stuff every now and then. Located in the Memphis area. All parts are best offer unless noted. Prices not including shipping unless noted. Email me for pics and offers notnilc20@hotmail.com
SOLD-aw11 manual steering rack good condition.
Aw11 4age hard line coolant ports (rusty) $30
Aw11 4age cam gear cover top part $35
SOLD-Aw11 mk1rear spoiler w/ 3rd brake light (needs paint)
SOLD Aw11 rear window spoiler painted black $60
Aw11 Air Flow Meter $40
Aw11 intake manifold $60
Aw11 spark plug valley cover $35
Ae86 parts
SOLD-Rwd hard water lines with thermostat housing and back housing portion of waterpump. $1,000,000
Radiator top brackets $20 ea.
Sr5 fuel lines that mount to fuel tank $30
Sr5 ac amplifier $20
Sr5 ac electrical harness $5
SOLD Zenki front corner lights $30 ea.
Kouki dr side corner light $40
Rear side marker lights $25 ea.
SOLD-Sr5 slave cyl.
Power mirror switch $35 shipped
Driver side kck panel fuse box cover with fuse diagram (maroon)$25 shipped.
Complete headlight assembly with motors both driver and passenger side color red, black zenki eye lids. Note: dr side missing blk plastic bezel surround. $200 Shipped!
Ae86 style spark plug valley cover with throttle cable bracket/support.$35
SOLD Zenki rear taillights for hatchback $110 shipped
SOLDMaroon color front seat belts $30 plus shipping
SOLD Sr5 rear plastic side bumper plastics $50 shipped
4age parts
(As of now I will sell all 16v 4age engine parts from a mr2 for $300 that is a complete bluetop 16v minus the crankshaft. (buyer pays shipping).
Oil filter sandwich plate the better version with hard feed line that goes up in between ps bracket and distributor. $80 (See pic below)
16v ignitor with coil (3 avail)
bluetop ecu m/t $80
4age cam gear cover top part only needs new 4age sticker $35
Bluetop Cam gears $25 ea.
Bluetop camshaft intake and exhaust $50 ea.
Bluetop Piston w/ connecting rod early model $30 ea.
Bluetop rod bearings complete set(new in box) $35
Bluetop Piston rings complete set(new in box) $35
Bluetop cylinder head complete w/ camshafts and cam gears w/o valve covers $175
Bluetop valve covers (needs paint) (4)
7-Rib block bare $100
Flywheel (came off aw11 not sure if it can be used with rwd)$25
Used clutch with pressure plate (looks like decent condition but it's made in china) $25
SOLD complete egr system w/ charcoal canister
Egr valve and tube from exhaust man. To intake man. $40
4age 16v fuel injector resistor (2) $30
4age oem fuel injectors (green) (4) $20 ea. Or $70 for all
SOLD 4age oem fuel rail with fpr $25
Tvis plate with vacuum actuator (2) $50
SOLD 4age distributor with cap and heatshield. Aw11 style but works with any 4age bluetop and maybe redtop. $70 (See pic below)
4age aw11 crank pulley chipped in a couple places but still fine $25
4age crank lower timing belt gear (2) $20
4age inner timing cover plate $25
4age 16v oil dipstick with housing $20
4age aw11 and ae86 style spark plug valley cover $35
Following 20v items all came from a Silvertop but some can be used with a Blacktop.
20v exhaust cam $200
20v intake cam $230
20v intake cam gear $220
SOLD- 20v valve cover- $100,000
20v cylinder head (valves installed, intake/exhaust cams, cam gears, vvti sensor, oe water in/out, rear heater in/out.) $400 obo
ae101 ecu $230
More to come!
sja4ag
Re: notnilc20's Ongoing For Sale Thread. Featured item aw11 Manual rack
Postby sja4ag » Tue Jan 10, 2017 12:22 am
Might need that ecu in a couple weeks. ill msg you if i do.
1985 hatch, 20v silvertop -- drift car (soon to be f20c swapped!)
1986 coupe, 20v blacktop -- daily
notnilc20
Postby notnilc20 » Tue Jan 10, 2017 12:25 am
sja4ag wrote:Might need that ecu in a couple weeks. ill msg you if i do.
Sounds good brother.
notnilc20
Re: notnilc20's Ongoing For Sale Thread. Featured item: 20v Silvertop head!
Postby notnilc20 » Fri Jan 13, 2017 8:40 pm
그냥...updated
Beams_AE86
Re: notnilc20's Ongoing For Sale Thread. Featured item: 4age Distributor w/ heat shield
Postby Beams_AE86 » Tue Jan 17, 2017 9:58 pm
Do you have GTS ZENKI axle shafts? Open or LSD?
notnilc20
Postby notnilc20 » Tue Jan 17, 2017 10:21 pm
Beams_AE86 wrote:Do you have GTS ZENKI axle shafts? Open or LSD?
Don't have those...sorry.
CloudStrife
Re: notnilc20's Ongoing For Sale Thread. Featured item: 4age Distributor w/ heat shield plus much more inside
Postby CloudStrife » Sat Jan 21, 2017 7:14 pm
Hey man is that disty rebuilt with seals and all?
How much?
Ian
notnilc20
Postby notnilc20 » Sat Jan 21, 2017 7:56 pm
CloudStrife wrote:Hey man is that disty rebuilt with seals and all?
How much?
Ian
Sent you a pm.
notnilc20
Postby notnilc20 » Sat Feb 18, 2017 8:04 pm
Sold some things...but stuff still for sale.
notnilc20
Postby notnilc20 » Wed Feb 22, 2017 9:11 pm
Put prices on most of the stuff.
notnilc20
Re: notnilc20's Ongoing For Sale Thread. Featured item: set of ae86 headlights plus much more inside
Postby notnilc20 » Tue Mar 07, 2017 9:58 pm
Get yours while you can.
notnilc20
Postby notnilc20 » Wed Mar 15, 2017 10:16 pm
Added an item or two and updated sold stuff. Bump.
notnilc20
Postby notnilc20 » Wed May 31, 2017 8:48 am
Bump this.
notnilc20
Postby notnilc20 » Sat Aug 26, 2017 12:27 pm
Ddddddddddddddddd
