ToeKnee's 4AGTE Build pt.2 (NOW w/MORE LEVINCOUPE)
ToeKnee805
Postby ToeKnee805 » Mon Aug 03, 2015 11:36 pm
Ok so, my part 1, had to 4AGE-T build up on my restored blue hatch. I decided to retire the blue hatch, and put a stock 4AGE back into it. You can read the full build thread here: viewtopic.php?f=7&t=11075
Here are the specs on the old pt. 1 setup:
HP: 150 RWHP
TQ: 163 RWTQ
Engine:
Stock Smallport 3 Rib Bluetop rebuilt 40k ago
.020 oversize pistons
New Main Bearings
New Rod Bearings
3 Angle Valve Job
Shaved Head
Decked Block
New Gaskets all around
T-VIS Fully Functional at 4700 RPM
EGR Emissions Deleted
Stock Ignition
TRD Plug Wires
New Timing Belt
5Zigen Catback
Homemade Adjustable Cam Gears
TurboSetup:
T25 SR20 Stock Turbo (Rebuilt by me)
Boosting 7lbs (wastegate)
CX Racing Log Manifold v.2
Custom 2.25 Downpipe (Exhaust Wrapped)
CX Racing Intercooler Kit
HKS Air Filter
Supra 440cc Injectors
Supra Injector Pigtails
Tercel/Paseo Brake Booster/Master (For Clearance)
Braided Turbo Feed Line
Restrictor Fitting for Turbo Feed
eBay bolt-on Oil Dump Tube for OilPan
10ft. or Coolant Hose to route Coolant Lines from IACV to Turbo
Stock Fuel Pump
Stock FPR
eBay Oil Catch Can w/ Filter
Electronics:
MegaSquirt PNP2 Standalone ECU Tuned By: CHURCH Automotive Testing
Glowshift Oil Temp Gauge
Glowshift Oil Pressure Gauge
Glowshift h20 Temp Gauge
ProSport Boost Gauge
INNOVATE MTX-L Wideband
Stock Tach, Speedo, and Fuel Gauges all Work
Wipers Functional
I acquired a Zenki Coupe GT-S that i pulled the engine from and was gonna use to GTS Swap my TE72, but decided to keep all 3 cars (Restored NA Kouki Hatch, TE72 Sedan, and Turbo my Zenki Coupe) So without further ado heres the pics from day 1:
Taking it home:
Long story short, the engine was "blown" and had 0 compression. Cams were installed incorrectly and dizzy was 180* off, but after i got everything timed right it fired right up perfectly. So on to pulling the engine i go:
And then it was time to put the turbo powerplant into the coupe, and swap the wheels over to take it for a test and tune at Willow Springs: [Click below for video]
Unfortunately while drifting the car while having messed up timing, the engine detonated and blew my ringlands on the 4th cylinder, and cracked them on cylinder 1.
So... back to the drawing board it was.. time to pull the engine again -_-
ToeKnee805
Re: ToeKnee's 4AGTE Build pt.2 (NOW w/MORE COUPE)
Postby ToeKnee805 » Mon Aug 03, 2015 11:59 pm
Seeing how the old block was pretty much toast, i had to find a new powerplant. I was running a bored 3rib Bluetop block, making my setup a 4AGE-T. Well i talked it over with everyones favorite corolla driver, and was able to come up with a deal where he would build me a short block out of a 4AGZE that he had, effectively making me 4AGTE now ^_^
Pictures of the rebuilt engine by TAKA:
Specs are
4AGZE
Bored .020"
OEM .020 GZE Piston
Stock Con-Rods
ACL Race Bearings (Mains)
ACL Race Bearings (Rods)
Decked block for Metal Headgasket
8.7 Compression Ratio (estimated w/ .8mm TRD Gasket)
Now that I had my block it was time to get some goodies: [THANK YOU BATTLEGARAGE RS]
Also, thanks to 86NTHEMIX for the sweet deal on a Manual Rack so I can clear my downpipe, since Power Racks are stupid and bulky!
When i had my old setup with the JUNK POS hks replica manifold i had to run a Tercel Booster, and a 2.25 Downpipe and it still had fitment issues. So i hit up the best person i could think of to build me a custom turbo manifold! YOSHIMITSUSPEED. Now with this manifold, i clear the stock booster, i can run a 3in downpipe, it will clear a manual rack, and it also clears the stock distributor. I dont have pics yet, but i dont want to reveal the design untill its mounted to my engine, just gotta say that his engineering and welds are top notch ****.
As of today 8-3-15 i have all the pieces to re assemble my build, but work is not letting me. Im hoping to have the engine on a stand Wednesday and start to put it all together. My goal was to finish before my bday in september but it doesnt look very possible.
PDB
Postby PDB » Tue Aug 04, 2015 12:24 am
Nice [emoji106]
ToeKnee805
Re: ToeKnee's 4AGTE Build pt.2 (NOW w/MORE LEVINCOUPE)
Postby ToeKnee805 » Sun Aug 09, 2015 10:32 pm
8-9-15
So I found a sick deal on a new front end for this car! It's gonna slow my engine building but I couldn't pass it up!
Levin hood, Lights, Fogs, Side Markers, Grille, Mudflaps, Kouki Rear bumper with bent bracketry, and a Zenki lip(for my other car)
I always thought Levins were shorter and it's true!!
If anyone can help me install these without fenders id greatly appreciate it, i tried mocking them up but I'm not sure where to drill the holes.
ToeKnee805
Postby ToeKnee805 » Tue Aug 11, 2015 10:42 pm
Engine building pics
Look at all that room for a big downpipe :o :o
As far as i can tell this will clear my stock booster and master setup. Its fairly close to the distributor so i may have to use a skinnier hose coupler adapter for my turbo outlet. I have yet to wrap my turbo manifold and a minor tune up (dizzy cap, rotor, plugs), and i want to paint my valve cover some sort of theme. I am also redoing all my rubber plumbing into steel braided line, and i think im ready to drop it in after that.
PDB
Postby PDB » Wed Aug 12, 2015 2:22 am
Take a few pictures of the turbo oil return you've put in the sump please.
ToeKnee805
Postby ToeKnee805 » Thu Aug 13, 2015 9:42 pm
Heres a few pics of my complete plumbing setup.
This is the oil Feed, to a T for my gauges, to the turbo feed, then you can see the dump coming out of the bottom of the turbo
Feed Closeup (stock oil pressure sensor locationL
Oil dump under turbo
Oil dump at Oil pan. As high as allowable
Coolant feed lines (stock metal lines that run to the throttle body)
And into the coolant ports on the turbo
ToeKnee805
Postby ToeKnee805 » Mon Aug 24, 2015 10:14 pm
More updates for you guys.
The engine is now in and fully mounted up. Heres a quick video... and some fitment pictures with a Tercel Booster. Fitment is super spot on, thanks Mr. Yoshi! Only issue is that i do have to space up my hood cause the turbo feed sits a little high.
Also finished piecing together the LEVIN front from a local bodykit guy, DMAX Replica took some massaging to fit, but its not bad looking for me not having headlight brackets and me having to mickey mouse some L Brackets.
Last but not least.. Color matched Steering wheel
I know alot of you guys dont approve of Ziptied Aero, and Knockoff kits, and Ebay steering wheels. But I decided to just have some fun this build, and go wild. because if youre too uptight about how your car is, and about having everything "Legit" name brand then youre worrying about the wrong stuff. Its all about driving your car, and having a blast, who cares if its ziptied together or has all OEM bolts! All corollas are sick corollas!.... and besides, i already have a clean JDM aero hatch i can baby while i abuse this.
ToeKnee805
Postby ToeKnee805 » Tue Sep 22, 2015 8:13 pm
dynod it for 181 rwhp @ 10psi, no one reads these lol so yeah
Clouds
Postby Clouds » Wed Sep 23, 2015 11:31 am
180whp is pretty impressive, man.
ToeKnee805
Postby ToeKnee805 » Thu May 12, 2016 2:31 am
Thought i would update this thread for the **** of it...
So again this car was Dyno'd at 181 RWHP on 10PSI of boost on a Dynojet rolling dyno. I believe it was 152 lb ft.
Was able to get some levin brackets off EPImporters on the cheap, and finished up the front end. I run a Fiberglass DMAX bumper on the track, and Plastic OEM kouki bumper with lip on the street. Also i found some RUNFREE skirts and they fit the car well. Just need Jblood valences to complete the look. Heres how it currently sits..
OEM aero, with skirts and foglights wired up. Took the wheels from the hatch also.
Fiberglass Bumper, SKirts, and a naked rear end..
Currently the car is sitting on jackstands..
Im switching the rear end from a Welded Zenki to a TRD 2way Kouki, swapping the T50 with a W55, and taking out the AJPS spacer to put in the DMAC offset spacer. Clutch is out at illegal garage getting resplined for W trans, and Rear end is at a diff shop getting Rebuilt, and the spacers are chillin on my table.
truenorican
Postby truenorican » Thu May 12, 2016 8:23 am
Both of your build logs are nice. I'm just starting up with my own SR5 to GTS conversion and I'll be checking back for your updates for sure!
JDM20VAE101
Postby JDM20VAE101 » Mon Nov 21, 2016 6:24 pm
Very Nice man!
Ivan's 4AGE BT 20V 6Spd LSD Build Thread
Just Scroll Down & Enjoy!
http://www.club4ag.com/forums/viewtopic.php?f=7&t=4529
Thanks For Looking! :D
Users browsing this forum: No registered users and 10 guests
