Carinna aa60 3a-u -T50/ 4a-ge 20v black Top Hi from Russia.
mert995
Postby mert995 » Tue Mar 17, 2015 1:07 am
The first part of the story.
viewtopic.php?f=4&t=3564&p=96244#p96244
my instagram "japanese.shop"
All work done with his father dvoem
Now raskaz about what has been done for 4 years.
bought the clutch basket and clutch release "exedy" on MT T50.
was bought by motor 4a-ge.
Made kontovatel to rotate the car.
engine installation
it took about half a year, cars stood almost untouched. Cooked inside of the rear wings
made sand blasting equipment
in 2012 there was a strong degree
Video
http://www.youtube.com/watch?v=bphq-WgsSEw
http://www.youtube.com/watch?v=KOhCF9TtolE
continuation will write later
Первая часть рассказа.
Всю работу делали двоем с отцом
А теперь расказ о том, что сделано за 4 года.
мой инстаграм
работали только с отцом
куплено сцепление, и выжимная корзина "экседи" на МКПП T50.
был куплен мотор 4a-ge.
Изготовлен контователь, для вращения автомобиля.
установка двигателя
прошло около полу года, авто стояло почти не тронутым. Сварили внутренние части задних крыльев
сделал пескоструй технику
в 2012 году был сильный град
продолжение напишу позже
mert995
Re: Carinna aa60 3a-u -T50/ 4a-ge 20v black Top Hi from Russ
Postby mert995 » Tue Mar 17, 2015 2:05 am
Was mauled threshold
cut out
made a new threshold
the rigidity of the body
drilled
straightened and secured by welding
Ve rests on the body with rust, of course he's not rotten, but to cover all anti corrosion, so after half a year rust went on. I didn't dare. continued
the search of the compressor.
working in a garage if possible.
try to do everything efficiently for yourself why so debt
Subscribe ! my instagram "japanese.shop"
mert995
был повтор
mert995
Postby mert995 » Tue Mar 17, 2015 5:02 am
made sandblasting
To be honest it is very difficult in this busy
to say dusty job , then there is nothing to say=)
сделал пескоструйную обработку
Скажу честно очень трудно таким делом заниматься
сказать пыльная работка , то есть нечего не сказать=)
mert995
Postby mert995 » Tue Mar 17, 2015 5:07 am
Wiring
ae111
Purchased automotive wiring
the engine compartment. salon
Куплена автомобильная проводка
подкапотная. салонная
mert995
Postby mert995 » Tue Mar 17, 2015 5:29 am
ПОЛИУРЕТАН
mert995
Postby mert995 » Tue Mar 17, 2015 6:30 am
INSTALL RADIATOR
well, this is how it sits now
After treatment by sand blasting the bottom from corrosion.
the bottom of the car looked like this here
then came the long-awaited moment when we covered the bottom with soil.
the Epoxy primer.
УСТАНОВКА РАДИАТОРА
ну и вот так вот он сейчас сидит
После обработки пескоструйкой дна от коррозии.
дно автомобиля выглядело вот так вот
настал тот долгожданный момент когда мы накрыли дно грунтом.
грунт Эпоксидный.
mert995
Postby mert995 » Tue Mar 17, 2015 6:54 am
Several layers of the soil
salon
protection
to lubricate the joints in the hind wings sealant
it was so
It happened
Coated with anti-stone chip
It's already on another day
the seams in the cabin
frame for optics
struck a white ground
[img]https://c-a.d-cd.net/1042ea4s-960.jpg
[/img]
Несколько слоев грунта
салон
промазать швы в задних крыльях герметиком
было так
так стало
Покрыл антигравием
Это уже на другой день
швы в салоне
рамки для оптики
нанесли белы грунт
mert995
Postby mert995 » Tue Mar 17, 2015 7:17 am
3 years have passed
video
https://youtu.be/uKUnAZp0aUg
mert995
Postby mert995 » Tue Mar 17, 2015 7:53 am
удалил повтор
mert995
epoxy primer,acrylic primer
primer body
first gray epoxy primer
then the usual white.
mert995
Postby mert995 » Tue Mar 17, 2015 7:59 am
videos dyeing machine
https://youtu.be/Wn2pnbNVazc
mert995
Postby mert995 » Tue Mar 17, 2015 8:19 am
the manufacture of the exhaust manifold
so it looks factory, under the front-wheel drive
Sketch
this is what happens=)
the real difficult task to do the exhaust manifold. someone experienced who knows=)
mert995
Postby mert995 » Tue Mar 17, 2015 8:32 am
polyurethane
the fuel pump. 2jz-gte
The gas tank. carburetor
on a lathe. did flange
under the puck from supriya
Hole sawed electric jig saw
welded to the tank thread
we filled up the water. Check for leaks.
mert995
Postby mert995 » Tue Mar 17, 2015 8:40 am
fuel line supra jza80
installation of the bridge
exhaust manifold
mert995
Postby mert995 » Tue Mar 17, 2015 8:51 am
the exhaust manifold.The final stage
spider 4.1
layout
did flange
[img]https://c-a.d-cd.net/f5f6d5cs-960.jpg
[/img]
you like? what we have done?
hung the exhaust pipe
under the exhaust was done about 6 mounts
wrapped the entire exhaust manifold thermo tape
do you like it? what we have done?
mert995
Postby mert995 » Tue Mar 17, 2015 9:38 am
salon carpet washed
scattered wiring in the garage from ae111 Levin
pasted interior sound insulation, rigid in two layers, gone 3-4 days
automotive wiring ae111
mert995
Postby mert995 » Tue Mar 17, 2015 1:09 pm
Cool light wheels Old School
Bridgestone ZANA SPOKE 6 MADE IN JAPAN
5 kg
it is time to bring them in proper form
well I washed them. about 30-60 minutes on each disk
Soaps with various detergents,they were very greasy
Then started polishing shelves
time about 4 hours on each disc
3 days is gone.
and the finish polishing for 30 minutes on the disc
prepared disks:
degreased, Packed in polyethylene.
and away we go
3 layers of gold and 4 coats of varnish
the camera does not convey the beauty=( from different angles in different color,
beautiful
You interested?
Should I continue?
MtLemmon86
Postby MtLemmon86 » Tue Mar 17, 2015 2:52 pm
Excellent work! Definitely keep us updated!
Grant
Postby Grant » Tue Mar 17, 2015 6:43 pm
Wow that's a lot of work. Keep it up and show us the finished result! :)
Jeonsah
Postby Jeonsah » Tue Mar 17, 2015 8:42 pm
Great work, keep it up! crazy russians! :]
mert995
Postby mert995 » Wed Mar 18, 2015 12:05 am
Good time dear readers.
We started the car.
here are two videos.
https://youtu.be/Tg5YC8Xt780
https://youtu.be/g7yYHKsUCoM
sorry that the forum is not to post the video so
mert995
Postby mert995 » Wed Mar 18, 2015 12:43 am
I will try to describe as much as possible just what is done.
here are the seats, they were on the roof of the shed 4 years=)
the interior was completely washed: carpet, trim, foam seats
Two sides of the driver's seat was worn out, I had to replace them
More or less reschedules with wires
this chip switches
set the stove
washed the motor janitors
https://c-a.d-cd.net/e82ca02s-960.jpg
started splicing wires. aa60-ae111
It's a difficult thing. I have no specialty electrics. but we did,carefully. and as needed.
Replaced the cord on the gas pedal, as the old one was short
on 14 February a Russian holiday. St. Valentine's day.
This day I spent in the garage. till about 2 am.
The salon after washing and sewing.
https://e-a.d-cd.net/b98ca02s-960.jpg
The salon is almost assembled.
mert995
Postby mert995 » Wed Mar 18, 2015 1:08 am
Brake lights, restoration
the car was purchased without stop signals.
Long sought brake lights, at that time in Russia I have not found, in Japan at the auction was not.
Somehow turned up option't remember exactly Ukraine or Belarus.
auto sawed in pieces and sold.
one stop signal was not glued, and the glass slides were on a delay=)
+ two stop signals were very dirty, about 3 hours I washed them
Since the optics was not new. there were chips, scratches, and cracks.
It was decided to revive them.
https://h-a.d-cd.net/3eede02s-960.jpg
Polishing
the initial state of the stop signal
https://f-a.d-cd.net/c3ede02s-960.jpg
polishing
Rama, on the stop signal
now do the same with the second
https://f-a.d-cd.net/3dde02s-960.jpg
https://f-a.d-cd.net/f01de02s-960.jpg
I think it turned out well
RuizXIII
Postby RuizXIII » Wed Mar 18, 2015 9:00 pm
Very nice!
You did good work making it look good again
irony.cc
mert995
Postby mert995 » Wed Mar 18, 2015 11:53 pm
RuizXIII wrote:Very nice!
Many thanks that you estimated our work =)
mert995
Postby mert995 » Thu Mar 19, 2015 2:46 am
Today there will be a post. This work literally the other day is finished.
Остлось slightly =)
Hello dear readers. one more board the magazine devoted to assembly of the car.
As the old cable of gas was short, other rope of gas is established.
Door glass, and moldings was bought
Here and so moldings looked
https://a-a.d-cd.net/91ecc42s-960.jpg
https://g-a.d-cd.net/71ecc42s-960.jpg
polishing
About the beginning looked so
- I established stoplights.
https://f-a.d-cd.net/291cc42s-960.jpg
established an oven faucet
Fastenings under conducting are made. established conducting that passes in front
as the radiator not native, and is one many more, from motor ge
fastenings of a radiator in the heel remade.
this time made fastenings of a radiator in the top part
Made fastenings and fixed the block of safety locks that under a cowl.
that's all =)
mert995
Postby mert995 » Sun Jul 26, 2015 7:43 am
mert995
Postby mert995 » Sun Jul 26, 2015 7:48 am
mert995
Postby mert995 » Sun Jul 26, 2015 7:51 am
