ONE MILD 86
ONE MILD 86
Hey Everyone,
This is my 2nd 86, first was written off...
I have a running build log over on another local forum but thought I would share over here at Club4AG.
Just photos on this first post!
Re: ONE MILD 86
This is what has been going since late 2013 till now, the BEAMS swap.
Here is a writeup by the shop that did most of the swap for me: http://cyriousgarageworks.com/swapped-beams-3sge-ae86/
Re: ONE MILD 86
Installed the CUSCO front radius bar... loks nice
Swapped out the 195/50 in front for a 225/50 to match the rear and installed the Zenki front lip
Re: ONE MILD 86
Is that a rx7/ae86 rear diffuser?
looks very nice! love that beams haha
- YOTAHOLIC808
Re: ONE MILD 86
Oh man.....makes me want to build my ae86 so bad but I have to wait till oct
R-Rydes
Re: ONE MILD 86
Sapporokid wrote:Is that a rx7/ae86 rear diffuser?
Yeah it is a Shine Auto RE-Amemiya Replica for FC
YOTAHOLIC808 wrote:Any vids of it running? ~ Looks amazing! good work!
No vids yet... maybe soon?
Oni-Roku wrote:Oh man.....makes me want to build my ae86 so bad but I have to wait till oct
Why the long wait?
Re: ONE MILD 86
Some updates from May.
Since then, I have just been driving the car as much as I can and been to a few track days.
Replaced the HAWK HP+ with WINMAX W4 pads and went with Rota Grid Classic 9J -15 & Hankook R-S3s in 225/45-15 for the track setup.
Really need to get an oil cooler setup going because temperatures were hitting 135 degrees after 5 hot laps.
The o-ring for the dipstick tube has a slight leak which only occurs on the track under constant high pressure.
That's about it for the problems so I am really satisfied, more lapping days to come.
Re: ONE MILD 86
are you gonna be there at the cyrious garage 86 meet next week?
Re: ONE MILD 86
Dope zenki! Flares and diffuser make it look raw
- grappletech
Re: ONE MILD 86
Nice beams swap
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
86 SR5 Hatch Shell
Re: ONE MILD 86
86 as it sits today,
it will never be done.
Re: ONE MILD 86
What adapter did you use for your quads? Xcessive? If so did the itg plate bolt right on?
Re: ONE MILD 86
It's sooooooo nice! Where is a drooling emoticon when I need it?
Re: ONE MILD 86
LongGrain wrote:What adapter did you use for your quads? Xcessive? If so did the itg plate bolt right on?
Xcessive yes, and the ITG plate from SQ did work but I ended up taking off those quick release fasteners and using bolts and nuts to secure the two together.
Slightly sanded down edges to make the fit tighter as well.
Your BEAMS86 is pretty rad by the way!
Clouds wrote:It's sooooooo nice! Where is a drooling emoticon when I need it?
Thanks!
Re: ONE MILD 86
lootbag wrote:LongGrain wrote:What adapter did you use for your quads? Xcessive? If so did the itg plate bolt right on?
Cool, thanks. I was curious because the ITB spacing with the xcessive adapater is a little different than it is on the 20v, so I wasnt sure if the bolt holes would all line up perfect.
Re: ONE MILD 86
LongGrain wrote:Cool, thanks. I was curious because the ITB spacing with the xcessive adapater is a little different than it is on the 20v, so I wasnt sure if the bolt holes would all line up perfect.
I believe the bolt and ITB holes lined up decently but need a tiny trim here and there.
Its been about a year since the swap, so the memory is a bit rusty.
Re: ONE MILD 86
Back in town and starting to spend some quality time with the car.
bumper cut and wanggg for now
working on some other things
Re: ONE MILD 86
That is one sexy corolla man!
"Life's simple. You make choices, and you don't look back."
Re: ONE MILD 86
Great Beams swap, and great looking 86! One question, how wide are the rims you running? Also, why did you chop up ur rear bumper for? Thanks and good luck on ur following track days!
Re: ONE MILD 86
Toy86 wrote:Great Beams swap, and great looking 86! One question, how wide are the rims you running? Also, why did you chop up ur rear bumper for? Thanks and good luck on ur following track days!
15x9 -15 square setup with 225/45-15 tires
Chop the bumper for "less drag", not really, its just for the look I like.
Re: ONE MILD 86
lootbag wrote:Installed the CUSCO front radius bar... loks nice
Pretty sure this is incorrectly installed...
Re: ONE MILD 86
ae86714 wrote:Pretty sure this is incorrectly installed...
Did I? I just followed what I saw on the web.
Re: ONE MILD 86
^That's right. I also have one.
Re: ONE MILD 86
My mistake, I was thinking it was supposed to attach to the ends of the tension rods like some other styles I've seen. And now looking at the bends in the cusco bar, it doesn't even look possible to attach the way i was thinking.
Re: ONE MILD 86
ae86714 wrote::oops: My mistake, I was thinking it was supposed to attach to the ends of the tension rods like some other styles I've seen. And now looking at the bends in the cusco bar, it doesn't even look possible to attach the way i was thinking.
Haha it's alright, I could see how that gets confusing.
CAD some new wingstands
Now the wing is roof height
Installed a fuel surge tank setup to deal with the pesky fuel cut in hard cornering
Free time attack session, so I joined.
Got bored and attempted to make a front splitter.
It is still a work in progress, need to make canards and endplates to finish the front aero.
This is the front end aero setup I am aiming for.
http://i.imgur.com/FSUxvsp.jpg
Re: ONE MILD 86
Nice build
Re: ONE MILD 86
what kind of wing is that ?
Re: ONE MILD 86
GTS_007 wrote:what kind of wing is that ?
Should be a Voltex Type 2 1600mm.
