When I take a corner, my front tires rub the fender.
Previous owner states I have Tokico shocks with unknown blue springs.
Currently running 16in XXR 513s with 195/45 Yokohama S.Drives
I have no idea how good/bad/cheap my suspension, wheels, and tires are.
Should I raise the car? Get lower profile tires? Stiffer suspension?
I like to do spirited driving, and heel-toe at any given corner.
Tires rub fender during cornering. What to do?
- VitriumGTS
Re: Tires rub fender during cornering. What to do?
Install some camber plates to adjust camber to negative, some slight fender rolling/pulling, and cutting the tabs off the front bumper and ziptie the bumper to the fender. An alignment would help too
16 is a little big for the corolla, 15 inchers with a bit of stretch will be helpful
Shakotan, Oni-kyan & Hippari a-go-go baby!
How are the quality of my parts?
- grappletech
I have 16x8's on the front of my car Adjustable coilovers and RCAs. and i barely get any rub on mine, its just on left turns if i lock the steering wheel and hit a bump lol. I used to have NCRCA's and I rubbed bad on everything.
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
86 SR5 Hatch Shell
Don't get skinnier tires if you like spirited driving. Like VitriumGTS said, get camberplates and roll the fenders.
I'm running 15x8 with 195/50, -2,5° camber and rolled lips, doesn't rub even when i'm driving on shitty roads.
FLAWLESS VICTORY
- gotzoom?
If you want better handling, running smaller wheels would also help. The car has a lot of unsprung weight, so anything you can do to reduce that is a good thing.
- HASport AE86
thanks sammy
SwangBiz Corolla Chassis Parts and F20/F22C/4AGE Wiring Services
(we build stuff, I solder wires, we race corollas, then we get drunk)
Proud Supporter of JSPfab.com, BattleGarage, and Solo8 LED Solutions
I wouldn't adjust the camber just for rubbing prevention purposes. Set your suspension the way it drives best to you, then make the car fit the tires/wheels by baseball bat or if you're patient modify the inner fender lip.
