AE86 Brake Booster (Found)
levinrolla8387
Postby levinrolla8387 » Wed Jan 03, 2018 1:33 pm
Looking for a brake booster for an AE86. Will pay for shipping to Cali. Thanks for the help.
Last edited by levinrolla8387 on Fri Jan 05, 2018 7:43 am, edited 1 time in total.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.”
― Albert Einstein
CloudStrife
Re: AE86 Brake Booster
Postby CloudStrife » Wed Jan 03, 2018 10:29 pm
You can buy them at your local parts stores.. It's really not something you should care about being factory..
levinrolla8387
Postby levinrolla8387 » Thu Jan 04, 2018 7:34 am
CloudStrife wrote:You can buy them at your local parts stores.. It's really not something you should care about being factory..
I looked into doing just that but I don't have any of the parts to bolt it down or the linkage to the brake pedal. Just sourcing oem parts since i'm working with a shell that didn't have anything.
― Albert Einstein
CloudStrife
Postby CloudStrife » Thu Jan 04, 2018 2:08 pm
I'm confused by what you're in need of. When you say "linkage", do you mean the actual pedal? Or do you mean the square bracket that is secured by 4 nuts? Or do you mean the push rod (plunger) linkage??
levinrolla8387
Postby levinrolla8387 » Fri Jan 05, 2018 7:38 am
CloudStrife wrote:I'm confused by what you're in need of. When you say "linkage", do you mean the actual pedal? Or do you mean the square bracket that is secured by 4 nuts? Or do you mean the push rod (plunger) linkage??
Sorry, I was talking about the U-shaped joint that connects to the brake pedal that is held on by a bolt and pin.
― Albert Einstein
CloudStrife
Re: AE86 Brake Booster (Found)
Postby CloudStrife » Fri Jan 05, 2018 11:32 am
When you buy a brake booster, it comes with that U-shaped joint.
levinrolla8387
Postby levinrolla8387 » Fri Jan 05, 2018 12:45 pm
CloudStrife wrote:When you buy a brake booster, it comes with that U-shaped joint.
I've ordered two of them so far and non offer the U-Joint with the booster.
― Albert Einstein
CloudStrife
Postby CloudStrife » Fri Jan 05, 2018 2:33 pm
Well, that sucks. Did you end up finding one?
Return to “Want to BUY (seeking sellers)”
