What's needed?
Max2503
What's needed?
Postby Max2503 » Fri Dec 08, 2017 9:42 am
I've swapped my old Ford engine for a 16v bigport running ST it's on an aftermarket ecu. Now before I commit to getting it setup, my friend has just pulled 170bhp and 148ftlbs torque out of the same old engine. Now what kind of set up would I need to match and hold my head high? :D
Re: What's needed?
Postby totta crolla » Fri Dec 08, 2017 10:48 am
Edited away my first response, it was a bit harsh !
When you say 'old engine' I guess you mean he is still using an old Ford engine ? Assuming his is 1600cc then it is nicely developed to produce the quoted numbers, especially torque. Relatively easy to match his hp but the torque in my opinion will be much more difficult and expensive using a 1600 4age. You might however be able to match or better his numbers by building a 7age (1800cc 4age)
Max2503
Re: What's needed?
Postby Max2503 » Sat Dec 09, 2017 2:47 am
Maybe I didn't explain well enough, I have taken an old Ford crossflow out of my car to place a 4age in. Now my friend has stuck with the crossflow and after alot of work squeezed the above figures out of it.
What would I need to do to achieve the same results out of a 4age 16v bigport (7 rib)
Re: What's needed?
Postby totta crolla » Sat Dec 09, 2017 3:31 am
His engine will most likely be bored to 1700cc, all steel and cost 8k ?
The normal recipe:
Compression (11.0:1 +) and capacity increase - Pistons
Camshafts - probably 288° +
Professionally flowed head
Decent intake- itb's or carbs
Decent exhaust
Programmable ecu
Approximately 6k (you already have itb's and ecu ?)
The right mix of parts put together properly should get you around 170hp but in my opinion he will still beat you on torque.
Start with an 1800cc bottom end (7age do a search) and I think you would stand a chance.
Most people would suggest you start with a different base 4age, a 20v blacktop and they would probably be right !
Re: What's needed?
Postby oldeskewltoy » Mon Dec 11, 2017 10:04 pm
hmmm Ford Kent making 170hp and 148 #/ft.... do tell, that is very good, exceptional really.... who built the engine??
Building 170hp 4AGE isnt difficult, but typically torque for that crank hp would be about 130-135 #/ft. 7AGE of 170hp may get you close to 145, maybe to 150.
