AE86 Thermostat
Swooki
AE86 Thermostat
Postby Swooki » Thu May 04, 2017 7:31 pm
Hey guys so i bought the oem thermostat from toyota but the only problem is that it didnt come with a gasket. So i went to a local autozone and bought these two.
which one am i supposed to use?
or both??
Also anyone have the diagram?
aukword1
Re: AE86 Thermostat
Postby aukword1 » Fri May 05, 2017 10:26 am
If i recall correctly the O ring one goes around the thermostat and the other gasket sits between the thermostat housing and the waterpump. Try them both and see if it fits but it seems correct to me to use both.
Re: AE86 Thermostat
Postby jondee86 » Fri May 05, 2017 2:30 pm
What I found was that there seem to be two types of housing. One has a shallow
(around 1mm) recess to hold the thermo, and that type uses the paper gasket. I think
that this is the type most common on older RWD Corollas. The other type has a deeper
recess (around 3mm) and this one is sized to use the rubber "O-ring" type gasket
wrapped around the outside edge of the thermo. You don't use the paper gasket as the
rubber ring provides the sealing.
You should be able to figure it out by looking at the recess in the housing.
jdm86gtz
Re: AE86 Thermostat
Postby jdm86gtz » Sat May 06, 2017 9:14 am
AE86 uses the paper gasket and AE92 uses the O-Ring
Swooki
Re: AE86 Thermostat
Postby Swooki » Sat May 06, 2017 11:52 pm
aukword1 wrote:If i recall correctly the O ring one goes around the thermostat and the other gasket sits between the thermostat housing and the waterpump. Try them both and see if it fits but it seems correct to me to use both.
These guys said to only use paper gasket.. hmm... because when i went to toyota and they showed me the diagram it didnt show any O rings. *confused* :?:
jondee86 wrote:What I found was that there seem to be two types of housing. One has a shallow
What's a recess? I=
jdm86gtz wrote:AE86 uses the paper gasket and AE92 uses the O-Ring
Oh Lol so i bought the O ring for nothing?
