OST-042-01: The Dubai Deception
mr2mk1hero
Re: OST-042-01: The Dubai Deception
Postby mr2mk1hero » Thu Oct 27, 2016 3:17 am
Looks cool as always! Toda springs?
Postby oldeskewltoy » Thu Oct 27, 2016 4:21 pm
mr2mk1hero wrote:Looks cool as always! Toda springs?
yes.... Toda springs should be enough to deal with the added boost pressure (now 14#s, before 8#s)
The head is assembled, I'm waiting on new valve shims...
Working on some of the logistics of getting this overseas....
build a cradle.... wood glue and screws...
and fitting said cradle into engine shipping case.... the 2x6s are screwed to the sheet of OSB, the blue ratchet straps will hold the engine to the cradle, and the box
more to come.... :D
Postby oldeskewltoy » Mon Oct 31, 2016 1:23 pm
Now comes the mating of the block and head. As requested I'm using ARP hardware
Studs set in the block.... Note upper right stud is just a tiny bit shorter
head is placed on the block
3 passes to 60#s.... after they are set to spec, 9 look a lot like this....
and one, the stud exposure is a bit less
more to come...... :D
jdm86gtz
Postby jdm86gtz » Mon Oct 31, 2016 5:35 pm
Did you stop deburring metal from around the bucket bores?
Ultimx
Postby Ultimx » Sun Dec 25, 2016 11:24 pm
Nice, can't wait to see updates
mr2mk1hero
Postby mr2mk1hero » Mon Dec 26, 2016 3:47 am
I just re-read this thread. Why did you put exhaust manifold gaskets on the exhaust side, I didn't see exhaust manifold gaskets on your other porting pics. I assume you matched the ports to the gasket in this case since these are not-so-mild cams and there will be more power, am I right?
Postby oldeskewltoy » Mon Dec 26, 2016 7:07 pm
mr2mk1hero wrote:I just re-read this thread. Why did you put exhaust manifold gaskets on the exhaust side, I didn't see exhaust manifold gaskets on your other porting pics. I assume you matched the ports to the gasket in this case since these are not-so-mild cams and there will be more power, am I right?
The exhaust gasket used is a new piece available in the past year - viewtopic.php?t=18129
In this engines case... yes the port outlet was pushed to close to the edge... making this the largest exhaust port I've made....
Postby oldeskewltoy » Sat Oct 21, 2017 1:24 pm
mr2mk1hero
Postby mr2mk1hero » Sun Oct 22, 2017 3:36 am
Look at that beautiful power curve. Only a supercharged 4age can have that. It's rising so aggressively right from the bottom! This must be a blast to drive. Amazing build right from start to finish. No wonder the SC AW11 was the fastest car in its time to 30mph or something. Correct me on this if I'm wrong.
Deuce Cam
Postby Deuce Cam » Sun Oct 22, 2017 6:27 am
Looks torque'y. A bet its a ton of fun.
