more to come.......
from another forum wrote:Interesting piston design, turbo/SC build?
from facebook wrote:There is no way that can only be -7CC dish. The actual dish looks deeper than the GZE and then those massive troughs on top of that? There is no way that piston has more compression than a gen 1 GZE.
Rogue-AE95 wrote:Interesting piston design. I like the concept, and I'm curious to hear how it does!
The Molnar rods -- no thrust side oiling hole, or side slot (like the BT rods)? I'm guessing those aren't the custom 40-20 rods that Orion had, based on the crank pictured above. My set of Orion 40-20 rods don't have any thrust side oiling. I considered having a machine shop add (or is that subtract??) the BT rod style side slots.
from another forum wrote:BTW: what's the reason you nicknamed it "The Dubai Deception"? A customer from Dubai perhaps?
oldeskewltoy wrote:As to drilling the big end to add a thrust side oiler, most shops say no when I ask....![]()
Are there any aftermarket "H" beam 4AGE rods with a thrust side oiler?
Rogue-AE95 wrote:
I can understand being apprehensive about drilling the hole (matched to the bearing). But I would think even that would be possible from a machine shop.![]()
Combustion Trough A term used to describe a feature on the piston crown between the intake and exhaust. Ignited air/fuel mixture on flat top and dish pistons typically have better flame travel than a dome piston. Flame travel on dome pistons can be improved with “fire slots” and/or a combustion trough.
not apprehensive.... most "H" beam rods are so hard that drilling them damages the drills, or so I've been told.
As to the 7AG rods with the blacktop type slots, I have not seen that before
BE Oil Squirters This oil hole in the Big End neck allows pressure fed oil to squirt up to the piston and rod Pin End for additional cooling and improved lubrication. This option can be considered for engines without oil squirters.
Rogue-AE95 wrote:I didn't realize the seats could be taken out. Are they pressed in then machined during the original head production?
from another forum wrote:will you do a flow test on this one?
oldeskewltoy wrote:using ARP studs
oldeskewltoy wrote:sooooooooooo..... back to THIS build......
Crank and rods are ready..... bearings selected
more to come.......
mad_86 wrote:oldeskewltoy wrote:sooooooooooo..... back to THIS build......
more to come.......
^^^^HAHAHAHA!!!!![]()
Nice Work OST!! Get down like James Brown, those Bowls look Smoooth!!
casket77 wrote:Running stock cam's ?
casket77 wrote:Looking Good!
Rogue-AE95 wrote:I've been meaning to ask, why is this build 042-01? Customer has two builds going on at once?
