Tires rub fender during cornering. What to do?
Crono0001
Postby Crono0001 » Sat Oct 12, 2013 3:11 pm
When I take a corner, my front tires rub the fender.
Previous owner states I have Tokico shocks with unknown blue springs.
Currently running 16in XXR 513s with 195/45 Yokohama S.Drives
I have no idea how good/bad/cheap my suspension, wheels, and tires are.
Should I raise the car? Get lower profile tires? Stiffer suspension?
I like to do spirited driving, and heel-toe at any given corner.
VitriumGTS
Re: Tires rub fender during cornering. What to do?
Postby VitriumGTS » Sat Oct 12, 2013 5:59 pm
Install some camber plates to adjust camber to negative, some slight fender rolling/pulling, and cutting the tabs off the front bumper and ziptie the bumper to the fender. An alignment would help too
16 is a little big for the corolla, 15 inchers with a bit of stretch will be helpful
Shakotan, Oni-kyan & Hippari a-go-go baby!
Crono0001
Postby Crono0001 » Sat Oct 12, 2013 7:04 pm
How are the quality of my parts?
grappletech
Postby grappletech » Sun Oct 13, 2013 12:17 am
I have 16x8's on the front of my car Adjustable coilovers and RCAs. and i barely get any rub on mine, its just on left turns if i lock the steering wheel and hit a bump lol. I used to have NCRCA's and I rubbed bad on everything.
87 GT-S Coupe Super Duper Clean
87 GT-S Coupe Beams 3sge (under construction because I'm slow and lazy and broke--- FML)
87 SR5 Coupe Shell. Who knows when I'll work on it.
-zenki-
Postby -zenki- » Sun Oct 13, 2013 11:13 am
Don't get skinnier tires if you like spirited driving. Like VitriumGTS said, get camberplates and roll the fenders.
I'm running 15x8 with 195/50, -2,5° camber and rolled lips, doesn't rub even when i'm driving on shitty roads.
FLAWLESS VICTORY
gotzoom?
Postby gotzoom? » Sun Oct 13, 2013 3:46 pm
If you want better handling, running smaller wheels would also help. The car has a lot of unsprung weight, so anything you can do to reduce that is a good thing.
HASport AE86
Postby HASport AE86 » Mon Oct 14, 2013 1:02 pm
thanks sammy
SwangBiz Corolla Chassis Parts and F20/F22C/4AGE Wiring Services
(we build stuff, I solder wires, we race corollas, then we get drunk)
Proud Supporter of JSPfab.com, BattleGarage, and Solo8 LED Solutions
PT86
Postby PT86 » Thu Oct 17, 2013 10:08 pm
I wouldn't adjust the camber just for rubbing prevention purposes. Set your suspension the way it drives best to you, then make the car fit the tires/wheels by baseball bat or if you're patient modify the inner fender lip.
