Are you really low guys all using over-axle exhausts?
SlideSexy
Postby SlideSexy » Mon Oct 07, 2013 10:48 pm
OK i changed the topic of my old Buddy Club Spec II post.
I have an underaxle SpecII, and I love the sound and such, but its really low.. and my car is on BC Coils, but theyre just installed, and i havent notched them down.. I want to lower the car another 1.5-2" and if i do that, It looks like I'll be destroying my exhaust..
So I'm just wondering, how are all of you LOW guys doing it? Do you all have over axle exhausts? If you have underaxles, how close is the exhaust to the ground? Do you have any pictures you could share?
ANYONE CAN BUY A NEW CAR. IT TAKES A TRUE ENTHUSIAST
TO BREATHE LIFE INTO AN OLDER ONE.
Re: Buddy Club Spec II exhaust users, help!
Postby MisterJerk » Tue Oct 08, 2013 8:03 am
Like all JDM exhausts. You need to either cut off the tow hook or bend it up. mine is bent up just enuff to clear my RS*R
carbd7age
Postby carbd7age » Tue Oct 08, 2013 12:30 pm
Had to cut mine off to clear my GReddy Ti-C.
Knockoff Crew member #0001
ae86xy
Postby ae86xy » Tue Oct 08, 2013 9:56 pm
Cut them off
ae86xy
Postby ae86xy » Tue Oct 08, 2013 9:57 pm
Cut them tow hooks off
carbd7age
Postby carbd7age » Wed Oct 09, 2013 6:42 am
Oh and a tip: cut the hook off before you try to mount the exhaust. I already had mine on and bolted down. It was super hard to cut it off with the exhaust on lol.
SlideSexy
Re: Are you really low guys all using over-axle exhausts?
Postby SlideSexy » Mon Oct 14, 2013 12:13 am
Changed the subject of post... bump
SidekickChuck
Postby SidekickChuck » Mon Oct 14, 2013 9:23 am
I have an axle over HKS Hi-Power. At one time, I considered an under axle setup, but I did not want to deal with ground clearance issues etc.
2001 Carbon Black e39 M5
LongGrain
Postby LongGrain » Mon Oct 14, 2013 10:07 am
i had a spec II on my car at this height.
was not an issue. That's on 14"s too.
SolidSTI
Postby SolidSTI » Mon Oct 14, 2013 10:32 am
I went from under-axle to over-axle. My tires are flush with the fender and the under-axle was the lowest point. It would scrape backing out of driveways and at other transitions.
1985 Corolla GT-S | 1985 Trueno Sprinter | 1989 Skyline GT-R | 2001 Prelude | 2005 STi | 2008 Forester XT| 1991 M923A1
http://TruFactsRacing.com
HASport AE86
Postby HASport AE86 » Mon Oct 14, 2013 1:18 pm
under diff....phuck it chicks dig sparks
SlideSexy
Postby SlideSexy » Mon Oct 14, 2013 1:30 pm
LongGrain wrote:i had a spec II on my car at this height.
I should have referenced your car. i've gone through that build thread of yours so many times LOL
Moto-P
Postby Moto-P » Mon Oct 14, 2013 3:24 pm
The advantages of running the exhaust on lower side of the differential is clear for an AE86 that's been dropped significantly because you run out of space over the axle, between the body floor.
However, do make careful measurements and limit the amount of suspension travel at 0 G's (tire off the ground) so that the suspension spring won't push the muffler pipe downwards with such force to cause issues.
The effects of doing it is you will get improvements in flow as you get rid of more kinks and twists in the tailpipe section, and you can have more suspension travel in the compression direction per design.
Most muffler shops will be able to custom make a tail-pipe under the axle, but to be very careful to run it close as possible to the axle with enough travel in the design, so that your clearance for suspension as well as ground height is at optimum position.
:D :D :D
Moto Miwa
founder, Club4AG
