Manual rack problems
Yatch
Postby Yatch » Fri Jan 11, 2013 12:49 pm
I recently got all the parts for the manual rack swap but ran into a problem with the rack itself. I turn it all the way left and it feels like it loses grip on the teeth in the rack. I have to tap the rod back in a lil bit then it catches again and I can turn right.
Any help would be appriciated thanks.
hachiroku ae86
Re: Manual rack problems
Postby hachiroku ae86 » Fri Jan 11, 2013 4:10 pm
if you turn it off the car it will do that when on the car it will stop before that point
Andrew Goodluck
email- hachitruenoae86@gmail.com
paypal- teenmob2@yahoo.com
cell- 909-697-7094
85coupe gtsr5 DDDM(dily driven drift missle)
98 ford f-150 DD blown up
Yatch
Postby Yatch » Fri Jan 11, 2013 8:10 pm
Oh ok thank you I thought I had a problem with the rack itself.
Thanks again
Postby Deuce Cam » Tue Jan 15, 2013 11:04 am
Are the inner tie rods installed on the rack when you try this? If so there shouldn't be a difference if it's installed on the car or not.
