Possible to convert SR5 rear axles to use disc brakes?
Rogue-AE95
Postby Rogue-AE95 » Fri Apr 26, 2013 1:44 pm
I've searched around the net trying to see if this has been done before, but I can't find anything. I suppose drum brakes aren't all that bad, but I'd prefer the easier maintenance of rear discs... but it's not like I will find a GT-S rear end very easily. So I'm wondering if anyone has ever kept their SR5 rear end, but converted it to use disc brakes. Would GT-S axle shafts with their disc brakes fit into the SR5 housing and diff? Is it possible to fit disc rotors onto the drum axle shafts? I'm thinking this would require custom fab work to get the calipers & brackets in place. I'm willing to try.
For the record, I have an '88 Corolla All-Trac, the rear end (supposedly) being basically the same rear as the AE86 SR5's (and perhaps the Tercel 4WD's).
carbd7age
Re: Possible to convert SR5 rear axles to use disc brakes?
Postby carbd7age » Fri Apr 26, 2013 6:46 pm
IF your rear end is the same as an AE86 SR5 rear end, YES. Go to hawkmachine.com you need different bearing retainers and caliper brackets from them, cheap. You'll be able to use Wilwood Dynamite calipers and Mitsubishi Galant rear rotors. Mess with the brake lines a little and hammer down.
Knockoff Crew member #0001
morgan
Postby morgan » Fri Apr 26, 2013 7:12 pm
Buy the last issue of 86Garage magazine, it tells you how to do this
My turd of an 86
20v swapped 86 write-up
Rogue-AE95
Postby Rogue-AE95 » Fri Apr 26, 2013 7:35 pm
:D Good to hear this, thanks. So that's all by using the SR5 axle shafts? Or do you still need GT-S axle shafts? That only leaves wondering about the parking brake cable and the prop valve.
I suppose the only problem I may have is that the All-Trac's lugs are 4x100. AE86 has 4x114. Hmm... at least there is hope and a starting point. I'm not worried about rims because I could pick up a set of aftermarket rims that have both 4x100 and 4x114 patterns.
morgan wrote:Buy the last issue of 86Garage magazine, it tells you how to do this
Thanks... had a look at their site. Do you mean the May 2012 issue? Says something about an SR5 disc rear end on the front cover.
morgan
Postby morgan » Fri Apr 26, 2013 7:39 pm
That be the one. Sr5 rear converted with disk brakes
My turd of an 86
Rogue-AE95
Postby Rogue-AE95 » Fri Apr 26, 2013 7:57 pm
I just tried to buy it but it's sold out. Augh! :(
morgan
Postby morgan » Fri Apr 26, 2013 8:21 pm
Remind me next week to scan it. PM me your email.
My turd of an 86
fort_city_prez
Postby fort_city_prez » Sat Apr 27, 2013 10:15 am
morgan wrote:Remind me next week to scan it. PM me your email.
Me too if you don't mind. I'm really looking at doing this. I'll pm you.
Cavi Mike
Postby Cavi Mike » Tue Apr 30, 2013 10:59 pm
You can't use GT-S axles in your rear end, they are larger. You're using your axles. I also believe in Japan there was a rare option of disc brakes with the small SR5 rear end.
pearls ain't free
morgan
Postby morgan » Wed May 01, 2013 11:54 am
^close, but in japan the base model 86 had an sr5 drum rear with an lsd.
sorry for the delay guys, i keep forgetting to scan the pages and post. wrote myself a note to hopefully remember today.
My turd of an 86
BlackStar
Postby BlackStar » Wed May 01, 2013 12:08 pm
I would be more interested in getting an LSD into the SR5 rear end. Pretty sure it was asked a lot on the old board.
Rogue-AE95
Postby Rogue-AE95 » Wed May 01, 2013 1:15 pm
morgan wrote:sorry for the delay guys, i keep forgetting to scan the pages and post. wrote myself a note to hopefully remember today.
No worries, take your time. I'm pretty far off from actually working on this. Doing my research for now. I still need to read up on suspension and what I want to do (front = AE92, rear = AE86).
BlackStar wrote:I would be more interested in getting an LSD into the SR5 rear end. Pretty sure it was asked a lot on the old board.
I'm wondering if the AE95 rear diff is an LSD or not. I mean it is AWD, wouldn't that be like LSD? More stuff I don't know about AWD / 4WD and things like LSDs. Although I thought SR5 guys could fit the GT-S LSD into the rear. I'm getting confused about the nature of my AE95's rear end now... I thought it could take the GT-S LSD because they're the same size rear. :?
morgan
Postby morgan » Fri May 03, 2013 9:05 am
well im glad i bought a bunch of copies of that issue before it was sold out, thats me on the cover!
emails of scanned pages in PDF format sent to you two.
morgan
My turd of an 86
Rogue-AE95
Postby Rogue-AE95 » Fri May 03, 2013 2:39 pm
Thanks Morgan! I still have some questions even after reading the article, but I'll re-read it a few more times before posting them here. One thing is that I thought Wilwood made 4-piston calipers which could take e-brake cables as well as the hydro lines. Hmmm.
And I'm thinking that the best thing to do once the 14mm spacers are finalized is to weld them to the brackets. I'm curious if the aluminum will hold up to use & abuse?
ga_goosh
Postby ga_goosh » Mon May 06, 2013 8:00 am
+1 that mag has the complete swap in it
I <3 my AE86
4AG Manual
AE86 FSM
morgan
Postby morgan » Mon May 06, 2013 8:27 am
yup, but my issues sold out Sean. you know if Jonas is making another printing of the Out Of Stock issues?
My turd of an 86
ga_goosh
Postby ga_goosh » Mon May 06, 2013 9:16 am
no I havent heard anything other then he has his hands full with these mags lol
I <3 my AE86
4AG Manual
AE86 FSM
Rogue-AE95
Postby Rogue-AE95 » Mon May 06, 2013 5:37 pm
morgan wrote:yup, but my issues sold out Sean. you know if Jonas is making another printing of the Out Of Stock issues?
If he did, I would still buy the magazine out of respect for having printed the article. I'm loving that there are options out there for those of us unlucky enough to have factory drum brakes. I'm just hoping I can make this work for an AE95, and maybe use those Wilwood calipers that have both hydraulic and cable brake capability. I'm sure my friend can help me fab something up if those Hawk parts won't work for me... but the hawk stuff is a great launching point.
morgan
Postby morgan » Mon May 06, 2013 5:42 pm
I'll email Jonas and see...
My turd of an 86
Imtrevorurnot
Postby Imtrevorurnot » Wed Jan 01, 2014 6:13 am
Would the same parts apply to the JDM AE86 GT-V with an LSD?
worloc918
Postby worloc918 » Mon Mar 03, 2014 9:25 am
Does anyone still have this pdf. I'm looking to do the swap on my SR5
rumsawatti
Postby rumsawatti » Tue Mar 04, 2014 6:25 pm
Isnt it cheaper and easier to just buy/find a GTS rear end then to do this conversion?
Slowdive
Postby Slowdive » Fri Apr 18, 2014 8:32 am
So I just tried to buy myself a copy, and as many others have stated, it's sold out. Could someone out there message me the PDF for this? I'd love to do a GTS swap, but finding one locally has produced more headaches than success. I figure it may just be easier to do the swap on my SR5 rear. I was planning on running a spool regardless of rear end, but man...drum breaks hurt my feelings. :P
morgan
Postby morgan » Fri Apr 18, 2014 8:45 am
Stop by my place, take pics or borrow a copy
My turd of an 86
Slowdive
Postby Slowdive » Sat Apr 19, 2014 7:18 pm
morgan wrote:Stop by my place, take pics or borrow a copy
Thanks for the offer, man. I'll take you up on this for sure!
jetmanblack
Postby jetmanblack » Tue Apr 22, 2014 9:39 am
Hey guys, I know this is a bit of an old thread, but can someone send me a copy of the article about the brake conversion? I have an sr5 that I'd like to swap the drums for disks too.
Rogue-AE95
Postby Rogue-AE95 » Wed May 07, 2014 5:55 pm
A year later, and I'm only at the parts-acquisition stage. I decided not to do the Wilwood calipers. The calipers with cable parking brakes are expensive. I thought about adapting AE92 Corolla GT-S rear calipers and discs to my AE95, but used parts go for too much. I'd be better off buying new / reman parts for not much more cost. I can't find AE92 GT-Ss anywhere around me in junkyards.
Well, I found an '88 MR2 in the junkyard recently. I pulled the rear calipers, and today I got my rear rotors. I only need one more parking brake cable and some other bits and pieces. I won't be able to do this conversion anytime soon, but at least I will have all my parts gathered up.
LEEJODA
Postby LEEJODA » Wed Oct 22, 2014 10:10 am
Hey guys,
Would anyone have a pdf file to share of that how-to swap? I'm just getting underway on a monster build w/ my wagon.
Glock30
Postby Glock30 » Wed Oct 22, 2014 10:21 am
Rogue-AE95 wrote:A year later, and I'm only at the parts-acquisition stage. I decided not to do the Wilwood calipers. The calipers with cable parking brakes are expensive. I thought about adapting AE92 Corolla GT-S rear calipers and discs to my AE95, but used parts go for too much. I'd be better off buying new / reman parts for not much more cost. I can't find AE92 GT-Ss anywhere around me in junkyards.
I'm very curious as to if you got the MR2 parts to work.
1984 Toyota Corolla Sport SR5
1989 Ford Bronco Eddie Bauer
1968 Ford F250
jetmanblack
Postby jetmanblack » Tue Dec 30, 2014 12:40 pm
Any news on this conversion?
