dash is retarded
Re: dash is retarded
Sounds like something isn't plugged in if all those items including lights are not functioning.
1985 Corolla GT-S | 1985 Trueno Sprinter | 1989 Skyline GT-R | 2001 Prelude | 2005 STi | 2008 Forester XT| 1991 M923A1
http://TruFactsRacing.com
Yeah, I'd check the plugs under the instrument panel & see what's goin on there. Not pluged in all the way maybe?
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
87 GTS Coupe
That sound in the back is most likely the wheel bearing if I was u I would save some cash n buy new ones on both sides get the seals and Timkin bearings dnt cheap out like I did n kept buying the cheap ones n having to replace them every three months get them on the warranty n before the one year warranty goes out change them again. Ohh also get the axle seals gaskets n new retainer from the dealer
Unless you are tiny, the easiest way to work under the dash is to unbolt the driver's seat and get it out of the way. Just makes sure to tighten it down properly again when you put it back.
Try tapping on the light dimmer and rotating it, it the lights suddenly turn on, that means the light switch assembly is coming apart internally, that's a known problem on these cars.
-- Original owner, 1985 GT-S
No, it's not the trip meter reset..it's the illumination dail around the light switch.
87 GTS Coupe
87 GTS Coupe
Red wrote:Unless you are tiny, the easiest way to work under the dash is to unbolt the driver's seat and get it out of the way. Just makes sure to tighten it down properly again when you put it back.
X2...I agree with you on that red. Threw my back out once bendin over backwards on that high part of the rocker.. Not fun
87 GTS Coupe
87 GTS Coupe
Kona-
Just don't ask me how many years it took to figure that out.<G>
Red wrote:Kona-
Lol...
87 GTS Coupe
87 GTS Coupe
