Help Identifying JDM front Zenki Turn Signal connectors
cincybranr
Postby cincybranr » Thu Jan 25, 2018 6:53 pm
Hey all,
I hope you can help me identify the Male connector pictured, so I can find the female sealed connector that plugs into it. This is a JDM Zenki front turn signal lamp. There is not a number of any kind on the plug. I’m not an electrical expert, and I am assuming the female will be sealed since this is a turn signal plug, and the OEM USDM female is sealed. Not always the case I know between usdm and JDM so DEFINITELY correct me if I’m wrong on this assumption.
Note: I know how to wire these lamps to make them work and work properly thanks to other post here, all I need is the connector information. Any help is appreciated for either the male connector or especially the female connector.
jdm86gtz
Re: Help Identifying JDM front Zenki Turn Signal connectors
Postby jdm86gtz » Tue Jan 30, 2018 2:31 pm
You could pop the pins out of the connectors and fit the US connectors to the jdm lamps.
I don't now if you have a park light in the US like the JDM lamp shown.
morgan
Postby morgan » Tue Jan 30, 2018 9:49 pm
Use a doner set of usdm lamps, clip those connectors off and put the usdm ones on the jdm lights. Then it plugs right in
cincybranr
Postby cincybranr » Wed Jan 31, 2018 12:53 pm
Hey guys, thanks for helping out. It seems that the JDM connector is not sealed which sort of surprises me considering the USDM male/female are sealed and they should be due to location/water etc. I Have decided to Pop the pins out of the connector, make a small adapter (I’m picky) and utilize the USDM plug back into the car. Thanks all!
