Beams swap question
povertymobile
Beams swap question
Postby povertymobile » Mon Oct 09, 2017 8:36 pm
Hey everyone,
Please forgive me if this is a dumb question, I've searched google far and wide and cannot seem to find a solid answer.
I am in the process of swapping a beams motor into my ae86, the engine is still out & I've got an ORC 309d clutch and flywheel kit to install. My question is would I need to find torque specs for the clutch and flywheel from the documentation that came with the kit? Or would I just use the stock torque numbers from the service manual?
If I'm supposed to use the factory numbers, does anyone have those torque specs? Since the engine was only made in japan I'm having a hard time finding anything online. Also the manual for the kit is completely in Japanese so while I can see some numbers, I'm not 100% sure what they're for, (though I can found one list that had SXE10 with some numbers so I am assuming this is one I'm looking for...possibly)
Thanks for any help!
aukword1
Re: Beams swap question
Postby aukword1 » Tue Oct 10, 2017 10:52 am
post pics of the instructions, my wife can translate the torque information. Also just fyi you might need this or make something similar to get the flywheel and clutch off and or on. http://www.sq-engineering.com/upgrade-p ... -tool.html
povertymobile
Postby povertymobile » Tue Oct 10, 2017 12:57 pm
Awesome! I'll post the photos tonight when I'm back home. Thanks for your help!
povertymobile
Postby povertymobile » Sat Oct 14, 2017 5:15 pm
Hey sorry fo
aukword1 wrote:post pics of the instructions, my wife can translate the torque information. Also just fyi you might need this or make something similar to get the flywheel and clutch off and or on. http://www.sq-engineering.com/upgrade-p ... -tool.html
Here's a link to the pdf of the manual, thanks again! https://drive.google.com/file/d/0B2oXKR ... sp=sharing
aukword1
Postby aukword1 » Sat Oct 14, 2017 9:54 pm
The wife says for the flywheel the torque is 107.8 nm which converts to 79.5 ft lbs. Hope that helps!
Autohaus_Z
Postby Autohaus_Z » Tue Oct 17, 2017 12:49 am
I just installed one of these with a customer. Flywheel and pressure plate bolt torques are in the manual measured in "nm." Check out the video. https://www.youtube.com/watch?v=S07hWTs0OxI
Follow me on Instagram @Autohaus_Z for AE86 fun, T50 trans builds, track life, and general automotive/fabrication work!
povertymobile
Postby povertymobile » Tue Oct 17, 2017 10:31 pm
aukword1 wrote:The wife says for the flywheel the torque is 107.8 nm which converts to 79.5 ft lbs. Hope that helps!
Awesome! Thank you so much!
Autohaus_Z wrote:I just installed one of these with a customer. Flywheel and pressure plate bolt torques are in the manual measured in "nm." Check out the video. https://www.youtube.com/watch?v=S07hWTs0OxI
Dude, this is so helpful. I have been putting off doing this job, but watching this helped to clear things up a little bit. Thank you.
