Another ae86/fc3/mini brake upgrade question.
4agshoob
Postby 4agshoob » Sun Mar 12, 2017 9:39 pm
So, ive got fc calipers, t3 brackets, silvermine 276mm drilled/slotted rotors, apex stainless lines.
Im researching before i purchase my master cylinder. Ive read 1" is overkill stiff, while the oem 13/16" is too long travel. With 7/8" and 15/16" hanging in the balance and 15/16 being on the "firmer" side.
I want to hear from you guys with manual brakes/no booster, who are running the fc brake setup. What do you have? How does it feel over stock?
Unfortunatly, my fiance's '99 ek civic got totaled back in 12/16. Fortunatly, ive already got her an ek9, and swapped all her stuff over. Just so happens her old master cylinder is a 7/8", and the 2 bolt holes line up with the toyota booster. Line holes are pretty legit in location too. Non abs car. Thoughts on the 7/8" master, with a booster delete?
Edit* car is being prepped for 1uzfe swap. Hence larger brakes. Yes i know the stock system with drilled/slotted rotors, dot5 fluid, ss lines, and good pads work well, (at least with a 220whp gze) but with more weight over the front, i wanted a bit more clamping force, over a larger diameter.
assassin10000
Re: Another ae86/fc3/mini brake upgrade question.
Postby assassin10000 » Wed Mar 29, 2017 3:40 pm
If your car runs, disconnect the booster vacuum line and go for a drive. It's preference. I run rx7/mini setup with stock booster, master with SS lines and it doesn't bother me at all.
Andrew
jinx
Postby jinx » Wed Mar 29, 2017 6:36 pm
u deleting the booster for UZ clearence ?
do u have a build thread for the 220whp GZE. Looks nice
