AC Panel Swap
Swooki
AC Panel Swap
Postby Swooki » Sun Feb 26, 2017 5:57 pm
How do i take out the white clip without breaking it....... I am trying to switch the AC Panel with a new one
http://i64.tinypic.com/111je6a.jpg
yellowsnow4free
Re: AC Panel Swap
Postby yellowsnow4free » Fri Mar 03, 2017 10:51 am
When I removed my AC panel I unclipped the attached cables on the other end, so the unit came out with the 4 cables attached.
I think you go in from underneath and spread the clip "prongs" out. Something like that... it has been a while since I've done it.
Swooki
Re: AC Panel Swap
Postby Swooki » Fri Mar 03, 2017 11:51 am
yellowsnow4free wrote:When I removed my AC panel I unclipped the attached cables on the other end, so the unit came out with the 4 cables attached.
I'm doing that but it just broke lmfao what is the clip called do you think the dealership will have extra
yellowsnow4free
Re: AC Panel Swap
Postby yellowsnow4free » Mon Apr 17, 2017 10:10 pm
Swooki wrote:
yellowsnow4free wrote:I'm doing that but it just broke lmfao what is the clip called do you think the dealership will have extra
("Holy late reply Batman!")
Here's the part # Jeff Lange has listed for said clip: 55933-10010
And a cross reference on said part # via ToyoDIY:
https://www.toyodiy.com/parts/xref?s=55933-10010&mU=on
(Although AE86's aren't listed above; odd)
Looks like you can pull that clip from a ton of Toyotas, so you could go junkyard hunting and grab a few. And if the AE86 part # is different you can cross reference it on ToyoDIY just like I did.
Jeff Lange
Re: AC Panel Swap
Postby Jeff Lange » Tue Dec 05, 2017 12:54 pm
The clip isn't listed separately for the AE86, but I assure you, that's the clip you're going to want. :)
Jeff
CloudStrife
Re: AC Panel Swap
Postby CloudStrife » Tue Dec 05, 2017 8:46 pm
I highly doubt that. I did some intensive research on Toyo Hvacs a little bit ago when I ran into a similar issue. Those clips change VERY frequently from generation to generation. The only 100% sure visual check I could complete was cross-referencing against Tercel, 4Runner, etc. early 80s chassis. I found after a certain year, the clips were similar in design, but completely incompatible for the AE86.
Actually, in the part call-out referenced, it says AE92. Bullshit. I'll go check my spare AE92 HVAC right now.
CloudStrife
Re: AC Panel Swap
Postby CloudStrife » Tue Dec 05, 2017 8:58 pm
1991 AE92:
https://www.ebay.com/itm/1991-TOYOTA-CO ... Fx&vxp=mtr
Completely different. I don't have the ability to check all chassis listed, but I would make absolutely sure before you buy. That is, if it's even in stock; that site is just cross-referencing part call-outs.
Just go to a JY. It's free pocket **** anyway.
I'm just stoked the almighty Mr.Lange is back...
