AE86 different power steering racks?
GZE_RA21
Postby GZE_RA21 » Wed Jan 25, 2017 10:25 am
Greetings fellow C4AGers!
here goes, I got 2 AE86 power steering racks from a guy on here who needed to get rid of them and they are identical. so with an extra PS rack on my hands, I wanted to try de-powering one of them based on i write up i saw over on hachiroku.com
im in the middle of an engine swap, so with the motor out i figured why not swap the looped line PS rack that came with the car for the one i de-powered while the rack is easily accessible?
But when I took the looped line PS rack out of my 85 GTS and compared it to the one I de-powered, I noticed they look sorta different. One is more narrow than the other and one has 3 bolts holding on the steering gear where as the other only has 2 bolts. Very strange.
I did some searching around and couldn't find a whole lot of info, is there a difference between zenki or kouki power steering racks? Are the SR5 and GTS racks different? or did i just not get AE86 racks from the other member here? was the looped line PS rack in my car not an original corolla rack?
funny because the write up pics on hachiroku.com showed the exact same rack that i de-powered...
anyway, just figured id run it by you guys to see what you think, thanks in advance people!
-BELOW- the one on the right is the de-powered rack, the dirty one is the one that came out of my car
SgtRauksauff
Re: AE86 different power steering racks?
Postby SgtRauksauff » Wed Jan 25, 2017 12:31 pm
Is that the difference between an MR2 and Corolla rack?
jdm86gtz
Postby jdm86gtz » Wed Jan 25, 2017 1:35 pm
In RHD cars the left rack is for early cars and right rack is for late cars(or at least those styles anyway)
GZE_RA21
Postby GZE_RA21 » Wed Jan 25, 2017 1:37 pm
SgtRauksauff wrote:Is that the difference between an MR2 and Corolla rack?
No, sorry i edited the OP for clarification. They are both of the racks that i have side by side. Supposedly they are both AE86 PS racks, im trying to figure out if that's true.
jdm86gtz wrote:In RHD cars the left rack is for early cars and right rack is for late cars(or at least those styles anyway)
Interesting, so there is a zenki and kouki PS rack? Could it be that I have a RHD PS rack?
jdm86gtz
Postby jdm86gtz » Wed Jan 25, 2017 1:43 pm
http://image.superstreetonline.com/f/15 ... g_rack.jpg
From their project car, looks similar to yours
GZE_RA21
Postby GZE_RA21 » Thu Jan 26, 2017 2:26 pm
I kept digging into it and apparently this is true for USDM / LHD cars as well, the power steering rack on the left in the picture above is a zenki power sterring rack and the one on the right is a kouki power steering rack. The inner steering shaft of both is the same length and the mounting points are the same distance apart, only difference being the diameter of the rack housing.
Users browsing this forum: Google Adsense [Bot] and 8 guests
