20V coil wire
ae86@661
20V coil wire
Postby ae86@661 » Tue Jan 10, 2017 7:59 am
I got the relocator kit from SQ and the 20v runs fine but I didn't buy the extended coil wire though, any idea where I can get extended coil wires or a alternative? As of now I am using 95 4Runner spark plug wires which works fine but the coil wire is still too short to reach my coil and igniter located by the battery.
SR85DET
Re: 20V coil wire
Postby SR85DET » Tue Jan 10, 2017 8:52 am
The extended wire was for cylinder number 4. Not the coil. I used the OEM coil wire and just mounted mine closer to the distributor where the battery used to be.
SR85DET
Re: 20V coil wire
Postby SR85DET » Tue Jan 10, 2017 8:59 am
To be more clear, I did get the extended wire from SQ (after originally not buying it) and did move my leads around so mine might be a little longer than whatever one you are using. But the extended lead is for number 4 according to the SQ site so idk what arrangement you have going on.
ae86@661
Re: 20V coil wire
Postby ae86@661 » Tue Jan 10, 2017 10:21 am
That's basically it...I didn't buy the lead wire to the coil from SQ, they charge $40 for 1 wire, I figure at the time there would be other options. As far a the spark plug wire go the 4runners work just fine.
ae86@661
Re: 20V coil wire
Postby ae86@661 » Thu Jan 12, 2017 3:45 pm
I just used an Lexus ES300 coil wire and it worked ,the lienght is perfect too
Users browsing this forum: Baidu [Spider] and 2 guests
