Hey guys. Can't figure out why my hazard light don't work
but my turn signals work?
Ae86 hazard light don't work
Re: Ae86 hazard light don't work
Check the fuse, then try replacing the flasher relay & hazard switch...good luck!
AE86Kai wrote:Check the fuse, then try replacing the flasher relay & hazard switch...good luck!
Where can i get a new flasher relay or switch?
Swooki wrote:AE86Kai wrote:Check the fuse, then try replacing the flasher relay & hazard switch...good luck!
Dealer and e-bay are only (2) locations that I can think for the new ones.
I am not sure if you can purchase any OEM replacement at your local auto parts store such as Pepboys or Autozone.
I would try hunt at junk yard as well.
It does not have to be from AE86 just look for the similar year of Toyota cars such as AE82, AW11, Tercel, Camry...etc.
Just for your information, AE86 Flasher Relay looks like image below and as you can see, Part # is : 81980-16010
AE86Kai wrote:Swooki wrote:AE86Kai wrote:Check the fuse, then try replacing the flasher relay & hazard switch...good luck!
Oh okay. Thank you so much!! I will try to go junk yard and find Mr2s. Or Ae92.
I couldn't find any hazard switch on eBay.
Also would any fuse from any car work for the hazard fuse?? I'm new to the automobile world and are confused.
Most Japanese cars uses same kind of Blade Type fuses during 80's. (AE86 uses "regular" type)
When you need to replace it, just make sure to replace it with SAME amp.
More information about automotive fuse can be found here.
https://en.wikipedia.org/wiki/Fuse_(automotive)
Good luck
Good luck
AE86Kai wrote:Most Japanese cars uses same kind of Blade Type fuses during 80's. (AE86 uses "regular" type)
Good luck
Thank you. Just checked the 10A Haz-Horn fuse and it looks intact. I can't seem to find the flasher relay and hazard switch looks fine? Idk maybe i'm tripping.
I couldn't find the flasher relay but i took everything apart and was messing with the wires and all of a sudden the hazard started working. but turn signal stopped working lol. so i kept messing with it and now it works. was it a wire problem?
hmm...very interesting.
Sounds like bad connection...anything could happen on old cars. Good luck!
AE86Kai wrote:hmm...very interesting.
Yep! All that matters is its fixed! Thanks bro!
