Ae86 hazard light don't work
Swooki
Postby Swooki » Sat Dec 24, 2016 8:21 pm
Hey guys. Can't figure out why my hazard light don't work
but my turn signals work?
AE86Kai
Re: Ae86 hazard light don't work
Postby AE86Kai » Sat Dec 24, 2016 11:23 pm
Check the fuse, then try replacing the flasher relay & hazard switch...good luck! :P
Swooki
Postby Swooki » Sun Dec 25, 2016 1:13 pm
AE86Kai wrote:Check the fuse, then try replacing the flasher relay & hazard switch...good luck! :P
Where can i get a new flasher relay or switch?
AE86Kai
Postby AE86Kai » Sun Dec 25, 2016 2:36 pm
Dealer and e-bay are only (2) locations that I can think for the new ones.
I am not sure if you can purchase any OEM replacement at your local auto parts store such as Pepboys or Autozone.
I would try hunt at junk yard as well.
It does not have to be from AE86 just look for the similar year of Toyota cars such as AE82, AW11, Tercel, Camry...etc.
Just for your information, AE86 Flasher Relay looks like image below and as you can see, Part # is : 81980-16010
Swooki
Postby Swooki » Sun Dec 25, 2016 8:10 pm
Oh okay. Thank you so much!! I will try to go junk yard and find Mr2s. Or Ae92.
I couldn't find any hazard switch on eBay.
Also would any fuse from any car work for the hazard fuse?? I'm new to the automobile world and are confused.
AE86Kai
Postby AE86Kai » Mon Dec 26, 2016 1:32 am
Most Japanese cars uses same kind of Blade Type fuses during 80's. (AE86 uses "regular" type)
When you need to replace it, just make sure to replace it with SAME amp.
More information about automotive fuse can be found here.
https://en.wikipedia.org/wiki/Fuse_(automotive)
Good luck ;)
Swooki
Postby Swooki » Mon Dec 26, 2016 5:46 pm
AE86Kai wrote:Most Japanese cars uses same kind of Blade Type fuses during 80's. (AE86 uses "regular" type)
Good luck ;)
Thank you. Just checked the 10A Haz-Horn fuse and it looks intact. I can't seem to find the flasher relay and hazard switch looks fine? Idk maybe i'm tripping.
AE86Kai
Postby AE86Kai » Tue Dec 27, 2016 3:54 am
Flasher Relay on AE86 is located on your driver side panel.
Since you have mentioned that your turn signal is working, it may be not the issue but, try turn on your signal and locate the little box that is making a clicking noise.
Swooki
Postby Swooki » Tue Dec 27, 2016 5:52 pm
AE86Kai wrote:Flasher Relay on AE86 is located on your driver side panel.
I couldn't find the flasher relay but i took everything apart and was messing with the wires and all of a sudden the hazard started working. but turn signal stopped working lol. so i kept messing with it and now it works. was it a wire problem?
AE86Kai
Postby AE86Kai » Wed Dec 28, 2016 1:40 am
hmm...very interesting.
Sounds like bad connection...anything could happen on old cars. Good luck! :mrgreen:
Swooki
Postby Swooki » Thu Dec 29, 2016 11:47 am
AE86Kai wrote:hmm...very interesting.
Yep! All that matters is its fixed! Thanks bro!
