I've looked everywhere to try to id this wire but looks like i'll need some club4ag expertise.
It is a black w/ white stripe with red dash(?). It is located on the gts ac wiring harness here is a picture of it. On the dash harness side of the plug there are only 2 wires (1)black and 2)red w/ blue). But on the gts ac harness side of the plug there is 3 wires 1)black, 2)red w/ blue like before and a 3rd black w/ white stripe and red dash wire).
The second pic is the elec wire diagram of the plug (plug I) that only shows the 2 wires. It says for 4age with powersteering as well. So i'm confused as to what this wire goes to.
Also i'm in the midst of installing the ac in my car and I can't get the compressor clutch to kick on. I'm thinking this wire has something to do with it....also the wire that goes to the ac compressor clutch is a black w/ white stripe wire with that same red dash.....PLEASE HELP! Thanks.
A/c wire identification mystery (looked in the ewd already)
Re: A/c wire identification mystery (looked in the ewd already)
Update.....i tried seeing if I was getting any power from this mystery wire while the ac switch was on and the car running. But no juice. Wonder if my pressure switch is working? How to test?
Is anybody out there?
- broku-hachi
I tried taking some pics for you. I don't know if they will do you much good. Some of my connectors look a little different.
This one is of the a/c harness.
windows print screen
This one shows it connected to dash harness. (white plugs on top of image)
image url
closer image
image hosting 12mb
The plug you have circled seems like the same plug, but mine only has a black with red dash.
It then connects to a male plug with a solid black and a red w/ blue stripe.
one more of the two coming from the dash
image url
image url
closer image
image hosting 12mb
image url
Thanks for the pics.. is the ac harness the original sr5 harness? Also is that a zenki gts underdash harness? I have that ac harness from the sr5 also.....it is the same as yours in the picture...wonder if the ac compressor will work with this harness? Thanks.
- broku-hachi
yup zenki underdash harness, and sr5 ac harness. I don't know too much about how to get the compressor to work, but I'm sure it's possible. I have a kouki gts dash harness with the ac harness as well, ill try and takes some pics for you at least for some kind of reference
Yes.....that would be great....thank you.
- broku-hachi
so these are the two connectors from the kouki dash harness
images hosting
Kouki A/C harness
free photo hosting
better view of other plugs.
post images
with two white plugs connected
image hosting over 5mb
screengrab
image hosting 10mb limit
images hosting
Kouki A/C harness
free photo hosting
post images
screengrab
Thanks a lot for those pics.... wonder why there are 3 wires on the female side of the ac harness plug and only 2 wires coming from the underdash harness? Why have a wire going nowhere? It just ends in the connector plug.....that's exactly how mine is.
Does anyone have a picture of a zenki gts ac harness? Is it the same as the kouki version that brokuhachi posted with the 3 wires going to the underdash harness on one of plugs? Thanks.
Nevermind...i got things working now.
Thanks for your help brokuHachi I got things figured out...here is part 2 of the ac install video
https://youtu.be/WLSNISShtTI
