ID this wiring harness please...
notnilc20
Postby notnilc20 » Tue Nov 15, 2016 6:43 pm
This was in my box o' parts but i'm not sure where it goes. My guess is the ac cooler unit under dash but let's get your opinion and is it sr5 or gts? Thanks.
matt dunn
Re: ID this wiring harness please...
Postby matt dunn » Thu Nov 17, 2016 11:51 pm
The part at the top which looks like two wires heatshinked together,
That is the A/C evaporator temperature sensor and goes into the AC box to control the temp so it does not freeze.
So the rest of it is probably all AC stuff too.
Postby Deuce Cam » Fri Nov 18, 2016 6:56 am
Its basically the sub harness for the ac evap and also is the idle up circuit for the fan. You also need the ac amplifier, but its probably still attached to the evap box.
notnilc20
Postby notnilc20 » Fri Nov 18, 2016 8:10 am
Thanks for your help guys. Yeah...i was able to get most of it connected but the large white plug on that harness does not fit my ac amplifier plug located on the cooler box. The cooler box is from an sr5....and i do have the harness for this as well that fits the ac amplifier plug. but my underdash harness has another plug that the sr5 ac harness doesn't have and this one pictured does have. So it's kind of a fuster cluck right now but i'm sure i can get it to work one way or another....
