Oil cooler lines routing with ac and ps.
Can anyone tell me the best way to route the oil cooler lines with the ac and powersteering intact? I'm putting ac back in my car and the ac lines go where the old oil cooler lines went. Thanks.
Re: Oil cooler lines routing with ac and ps.
The original oil cooler hoses run between the tension rod bracket and the front left chassis leg, push the thin metal flap on the tension rod bracket down to allow room for the hoses.
jdm86gtz wrote:The original oil cooler hoses run between the tension rod bracket and the front left chassis leg, push the thin metal flap on the tension rod bracket down to allow room for the hoses.
Oh great....I was looking down there and was trying to find a spot to route the hoses and that's exactly where I figured the next best spot would be aside from where the ac lines go through....thanks for your help.
