Rear reflector delete
NW86
Postby NW86 » Wed Jul 08, 2015 8:17 pm
Does anyone have experience or know of a decent write up when it comes to deleting the rear reflectors on the quarter panels? I don't have any experience doing body work so I don't really know where to begin. This is something I have to do to this car but I don't want to miss a step and mess it up. Let me know guys thanks any help will be much appreciated
saiGone
Re: Rear reflector delete
Postby saiGone » Thu Jul 09, 2015 7:00 am
Best way is to weld a small plate behind and smooth out with bondo. Good Luck.
MisterJerk
Postby MisterJerk » Thu Jul 09, 2015 12:59 pm
saiGone wrote:Best way is to weld a small plate behind and smooth out with bondo. Good Luck.
the correct way ^^
you could fiber glass it from the inside and bondo it, but it will probably crack or come out or do something a welded in plate will not do
NW86
Postby NW86 » Thu Jul 09, 2015 4:36 pm
thanks guys that helps put things into better perspective
smackdownz
Postby smackdownz » Sat Jul 11, 2015 3:35 am
yep if you can weld, put a small filler behind the panel (below the surface) and then bog smooth, if not fibreglass and bog :D
saiGone
Postby saiGone » Wed Jul 29, 2015 8:14 am
Over fenders cover the whole area as well . 0_o
