Greetings Guys,
Im considering the 3SGE Beams swap, as it seems to be a pretty stout 2.0 N\A motor. I want to keep this in the Toyota Family so no F series honda motor suggestions thanks.
Im really NOT interested in cutting my trans tunnel or frame to make this fit. So what I can't determine is if I can get a transmission that will stick out of the stock shifter hole, and bolt to the rear of the 3SGE engine.
Thanks!
School me on the 3SGE Swap
- gotzoom?
Re: School me on the 3SGE Swap
You'll need to cut the trans tunnel. The shift lever is not in the same place. That said, a BEAMS powered car is pretty epic!
I took a guy for a ride on Laguna Seca last month and he had a camera on his helmet, so you can get an idea what it looks and sounds like. I was driving a buddy's car.
https://www.youtube.com/watch?v=5vzzU7TULWc
Re-using the 3SGE 6spd, I know you must cut the tunnel, Im curious if another transmission can be bolted up to the 3S, or the bellhousing, to create a 5spd swap option , or anyway, to make the beams work without the cut.
If I must cut, i'll probably scrap the 3S idea, and move back to my previous thought process.
Thanks!
Thanks!
peep this guy's worklog (not exactly the same since it's a 3sge going to a 5sgte). it might give you some insight - http://hachiroku.net/forums/showthread. ... sgte+build. he's on c4ag as bnicolas and he's selling this car in the classified section too. looks like he used a w55 transimission with custom bellhousing and driveshaft.
if you can find a shifter from Leen(the guys who brought the adaptor for the 6speed for the 4age.)
Im guessing they are now out of biz, since their site is down now.
here's a pic:
here's a pic:
Or you could do a mod like this guy to relocate the shifter on the 6 speed: http://www.aeu86.org/forum/showthread.p ... 31&page=51
- grappletech
http://www.ae86drivingclub.com.au/forum ... (inc-Beams)-into-AE-KE-thread
This is a good starting place . If you have any specific questions I'll point you in the right direction...
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
86 SR5 Hatch Shell
^Awesome thread, thanks!
