valve shims
valve shims
im rebuilding a blue oem.
and none of my extra shims are thin enough! according to the factory manuel... how do grind the shims to size?
and how does that shim less bucket conversion work? how is the clearance compensated for that?
Re: valve shims
you will have to get new shims. i would not try to grind them down. just get the correct sizes. for the shimless buckets you can get a set from a yaris. they fit the 4age perfectly. the shim is simply built into the bucket. instead of changing shims you would change buckets.
Re: valve shims
If the shims listed for the 4ag are not small enough there are thinner shims from another Toyota motor that will work. Let me know if you need part numbers. If your in SoCal I have a bunch of shims too.
Re: valve shims
Here are the part numbers actually in case anyone else may need them some day.
Btw. If you have to use any of these smaller sizes then you will not be able to do the buckets unless you grind your valves shorter.
Re: valve shims
ethergore2 wrote:If the shims listed for the 4ag are not small enough there are thinner shims from another Toyota motor that will work. Let me know if you need part numbers. If your in SoCal I have a bunch of shims too.
i left my notebook where i did all the calculations at my garage. then i ll know what size i need i think it was in the lower 2.00s. so all these thinkness is available? and will work with bluetop buckets?
thanks guys so much!
Re: valve shims
post the izes you need in inches.
I have a whole case of them
Max
Max
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Maxfrommisawa@aol.com
U.S. 7th Fleet
VQ-5 Det 5
VQ-1
Re: valve shims
Illegal_Garage wrote:post the izes you need in inches.
Max
will do thank you!
Re: valve shims
http://www.cylinderheadsupply.com/valve ... -25mm.html
as thin as 2.3mm, and quite a bit less expensive then Toyota
Re: valve shims
OST-I'm bookmarking that site. Thanks.
Re: valve shims
i need
2.60 or anything lower x2
2.72 x2
2.73
2.74
2.75
2.78
please if anyone has these shim sizes! ill buy it off you thanks!!!
2.72 x2
2.73
2.74
2.75
2.78
Re: valve shims
runkillerrabbit wrote:i need
2.72 x2
2.73
2.74
2.75
2.78
Ill see what I have when I get home. With those numbers you could probably do bucket-less shims.
Re: valve shims
eventually i might convert it to shimless.. but this is my budget oem/ junk yard build.
Re: valve shims
Here is what I have. I measured in inches and then converted to mm. Some readings were so close in inches that they converted to the same mm so I'm not sure how to interpret which shim they are. To be the most accurate I suggest comparing what I have to what you need in inches.
Here is what I have in inches:
Here is what I have in mm:
Let me know if I can help.
Re: valve shims
thanks man! ill let you know what i need soon where are you located?
Re: valve shims
SoCal
