Gonna start a build and see where it goes ===> TWINSCREW !!! :-p
Jeonsah
Re: Gonna start a build and see where it goes ===> TWINSCREW !!! :-p
Postby Jeonsah » Wed Jan 24, 2018 6:32 am
Love your car! Looks like it was a fun event. Keep giving us more updates!
Postby jondee86 » Thu Jan 25, 2018 4:14 pm
Jayrdee wrote:You should post up pictures of your car more often!!
I have a few pics of my car standing still, but because I don't let anyone else
drive it, basically zero pics of it moving. That one from last weekend is the
first "action shot" ever :)
But the photographer seems to attend all the local events, so I am hoping that
I might be able to get a few more action pics from her at future events.
Postby jondee86 » Mon Jan 29, 2018 5:47 pm
Been having a problem in getting a bypass valve to work on my setup. After messing
around with a Bosch valve and then the GFB 9301 valve, I have discovered that neither
of them will work. They are designed for turbo or centrifugal s/c applications, not for
a positive displacement s/c where the throttle is before the s/c.
There are other types of bypass valve that will work, but none of them are easy to fit
with my layout which already has the spigots welded on for the Bosch valve. So to cut a
long story short, I figured a way to use the GFB valve :)
I took the vacuum tank and solenoid from a TVIS engine and plumbed it up to manifold
pressure and the GFB valve. The solenoid valve allows either vacuum or boost to act on
the GFB valve, depending on whether the solenoid is energised or not.
I have programmed my ECU to switch the solenoid valve at a certain MAP reading. So
the GFB valve is open below that reading to reduce inlet temps at cruise, but closed
above to avoid any loss of boost. Backyard engineering at its best... works great :D
EDIT: Bit of an update on this mod for the tech heads :) After a few weeks of running
with this setup I discovered a flaw. When cruising and using a little bit of boost now and
then, but never actually coming right off the throttle, the valve would not open when the
MAP dropped below my switching setpoint. The vacuum tank only held enough vacuum
for one actuation... after that it needed to be recharged by seeing overrun vacuum.
However, I had recently discovered that with my setup (throttle before s/c) the vacuum
before the s/c was stronger than the vacuum after the s/c. So by way of an experiment
I changed the plumbing to put vacuum from before the s/c on the vacuum tank. Seems to
have worked, as now I can feel that little nudge of acceleration each time the valve opens
when MAP rises past my switching point. Vacuum recharge on the fly 8-)
jinx
Postby jinx » Tue Jan 30, 2018 1:17 am
true hotrodding! sharp mind
Postby jondee86 » Sun Feb 25, 2018 5:58 pm
Pits area for last Sunday's hill climb...
Video here... https://youtu.be/eLNpIjOa02E
Used my street tires for the day as I discovered that my "race rubber" that came with
the Enkei wheels must have been handed down from father to son !!! Eleven years old
according to the markings which accounts for the fact that they didn't have much grip :)
But I took a couple with me just in case of punctures. Might have to spring for some
new rubber if I decide to keep doing these events for another year.
Postby jondee86 » Mon Feb 26, 2018 2:57 pm
When I bought my s/c it was supplied with fill and drain plugs, but did not have
a dipstick or sightglass for checking the oil level. The factory kitset s/c's have these
as the factory knows how the s/c will be mounted and can put the dipstick in the
correct place on the s/c. Not a biggie as I can use a ziptie for a dipstick :)
But having worked for a business that sold industrial gearboxes, I did wonder why
the s/c gearcase had no provision for venting. When the gearcase heats up under
load, the air inside expands and creates pressure which can lead to oil being forced
out thru the shaft seals. Then I read about a company making a breather kit to fit
the same s/c that is used in BZR/86 kits, and decided I should have a filter/breather.
These are available in most countries, but apparently unobtainable in NZ... one of
the penalties for being at the bottom of the world. So I made my own...
Found an M12 x 1.5 to 1/8" BSP adapter and a 1/8" bsp sintered bronze compressed
air silencer (used on control valve exhaust ports). Whittled down a piece of plastic
to make a "pellet" just big enough to fit inside the adapter without falling thru, and
held in place by the filter. Used the smallest drill I have (<1mm) to make a hole in
the pellet and plugged it into the gearcase in place of a fill plug.
Seems to work as no sign of oil coming out. :)
aukword1
Postby aukword1 » Mon Feb 26, 2018 4:13 pm
Now that is some nice innovative thinking there. This is by far one of the coolest builds I've seen so far.
Postby jondee86 » Sat Mar 10, 2018 2:30 pm
Had a look around to see what was available in a decent trackday tire that I could
drive to the event on and compete with, to avoid the hassle of carrying another set
of wheels. Not much choice when it comes to 14's so I decided on a set of these...
Direzza Z2 185/60-14 as I run 6" wide wheels and 185's seem to work OK at my modest
power level. When they turned up for fitting they looked a little skinny, and yes, the
tread width is less than the section width. Made them look skinny when compared to
the 888's that have a tread width about the same as the section width. Can't see it
being a problem as fresh rubber is always going to grip better than 11 year old rubber :)
Got an event coming up next weekend so will see how they work.
aukword1
Postby aukword1 » Mon Mar 12, 2018 7:40 am
Take some video at the event next week! Lets see that new rubber in action :)
CloudStrife
Postby CloudStrife » Mon Mar 12, 2018 2:20 pm
That's why I always go 15s. The modest increase of the wheel weight is nothing compared to the amazing selection that reveals itself to you when you bump up an inch from 14.
I remember scouring through tirerack and the internet for decent 14s on my Mazda Familia. I just gave up and never bothered going back to 14s. The market just doesn't care..
Postby jondee86 » Sun Mar 18, 2018 2:58 am
Things to do on a beautiful Sunday morning.... driver's eye view going up... :)
https://youtu.be/8pSyUqAevKA
And then coming down at a more leisurely pace.
https://youtu.be/Yc51RZj7WkU
Hill climb on a piece of road closed for the event. Not a lot of traction but the
new tires worked OK. Driver has to learn to pedal harder :)
aukword1
Postby aukword1 » Mon Mar 19, 2018 7:29 am
Very nice runs, That car is amazing and sounds even better. Looks like loads of fun to drive. Glad everything is running well.
Postby oldeskewltoy » Mon Mar 19, 2018 7:30 am
jondee86 wrote:Things to do on a beautiful Sunday morning.... driver's eye view going up... :)
86_dorifto
Postby 86_dorifto » Mon Mar 19, 2018 12:56 pm
Those were some awesome videos! Thanks for sharing. The car looks cool and sounds like it's running great.
KAZATO - 85 GTS Coupe
Postby jondee86 » Mon Mar 19, 2018 2:38 pm
Appreciate the comments :) This is grassroots motorsport... guys building cars in
the backyard in their spare time and then bringing them out to have some fun in a
safe environment. Of course there is a full spectrum from high performance road
cars to Euro classics and every kind of modified Jap road, rally or drift car.
You don't need to have a high dollar vehicle to take part. So long as your car meets
the basic safety standards, you are in !!! I enjoy having a day out to talk cars and
see what other guys are driving. Car clubs are a great way to get into motorsport
and meet people who are as passionate about their cars as you are about yours :)
Postby jondee86 » Fri Mar 23, 2018 9:39 pm
Got some TT132 lower control arms to go in the car. They are a little bit longer than
the factory AE86 lower arms and I'm hoping for an extra one degree of negative camber.
That should take me to 1.5deg negative which (IMO) is about ideal for a road car.
Fitted new TRD rubber bushings and new ball joints while I was in there, as I don't know
if the original ones had ever been changed.
Postby jondee86 » Tue Mar 27, 2018 7:07 pm
Lot of dicking around to get these installed. But they are all done now and toe-in
set in my garage. Went for a drive to pick up some grease and car handled perfect
on the highway. It is such a small increase in camber that I didn't expect it to really
feel any different.
The test will come in a couple of days when I have an event that has chicanes to
keep speeds down, so plenty of opportunities to see if it turns in any better. No
idea what the caster is just now, but the steering does not feel any heavier, so it
probably hasn't changed much from stock.
Postby jondee86 » Fri Mar 30, 2018 1:59 am
Had an awesome day for this event. Cold and misty in the early morning but a
beautiful fine day to follow for the racing. Here is the uphill video. See if you can
pick the exact moment of the "inverse money shift" :)
https://youtu.be/ZHqRn1DcjfA
Returning down the hill in convoy for contrast...
https://youtu.be/7zfivgI2aIA
Good Friday was really good this year :)
Jayrdee
Postby Jayrdee » Fri Mar 30, 2018 8:15 am
Looks like loads of fun!
Hearing the whine of the supercharger is a good little change compared to what the typical AE86 with a 4age sounds like!
8===D~~ \\(*_*)//
_____________________
instagram: @JacobDurbin
aukword1
Postby aukword1 » Fri Mar 30, 2018 8:48 am
Did you notice a significant different after swapping the LCA's? Second video link isn't working btw. Those events look like they are so much fun!
Postby jondee86 » Fri Mar 30, 2018 1:06 pm
Ahhh... the upload on the second video stalled, and somehow it got switched to
private instead of public. Should be working now. That uphill was shaping up to be
my fastest run of the day until I hit 5th instead of 3rd :oops: :oops:
Can't say I noticed any difference from the slightly longer LCA's. Car was drifting
sideways a bit on the corners and uphill is not a good test. In the past I have found
downhill and braking into corners is a better test of turn in, so I reserve judgement
until I have done some driving on my usual test track :)
EDIT: Car definitely turns in better now. Not a night and day difference, but enough
to make me a little more confident that the car will stick when hitting tight bends
with a bit of speed on. Can't see any downside to this mod.
Bit hard to tell from the drivers seat but I think that my exhaust resonator has lost
its acoustic packing. The car seems a bit loud and the tone has changed, so need
get that looked at and replaced. Always something standing waiting with its hand
out for cash !!!
scalpel
Postby scalpel » Sat Mar 31, 2018 10:21 am
nice vids and so clean
Postby jondee86 » Tue Apr 03, 2018 9:28 pm
Ever since I have had this car I have had a problem with bad reflection from the
dash pad onto the windscreen when driving into the sun. Sometimes it was so bad
I had to slow to a crawl as I just couldn't see if there were parked vehicles when
the side of the road was in shade from a fenceline or hedge.
This is a problem that is made worse if the dash pad has been treated with a vinyl
preservative, and mine had been. So I was looking to see what could be done to
improve the situation. Rally guys usually get the dash pad flocked, but I couldn't face
the hassle of removing the dash pad, and I only really needed to kill the reflection
off the hood above the instrument panel. So a DIY hack was needed :)
I bought a square of 1mm black wool felt and trimmed it to the shape of the hood.
Then I used a "sticky jelly pad" cut in half to hold the edges and stop the felt sliding
around. Now, I can see the relection of the jelly pads as they are quite shiney, but
the critical vision area area to the front is virtually reflection free.
