Red Coupe Rebirth
Red Coupe Rebirth
*** Going to bring this back, missing a lot of stuff ***
I used to own a red coupe that to this day i regret i ever sold it... and when this sprung up on club4ag for sale, i knew i had to buy it.
1987 Toyota Corolla GT-S Coupe
Non-Sunroof
Low Trim (SR5) Interior
AE111 20V Blacktop
T3 Velocity Stacks
Cusco Catch Can
Koyo Radiator w/ Electric Fan
Haltech E6X
Techno Pro Spirits Club4ag Header
HKS(?) Exhaust
Hiflow Cat
Greddy Coil Overs
UEO Strut Bars (front and rear)
Nagisa Shock Tower Plates
KAAZ 2-Way LSD
The car however did not come without it's demons...
- Car was faded red, not the worst i've seen but we all know how the Toyota red gets.
- Headlights did not move up or down.
- Rust on the passengerside 1/4 panel.
- Brakes were spotty at best.
- Exhaust leak somewhere (fumes were getting inside the cabin during stops)
So with the help of my brother, we gave the car a quick wax which brought back the Toyota red shine!
And after reconnecting the headlight relay, the headlights opened and closed perfectly!
Rust on the 1/4 panel was solved with sanding, primer, and RED electrical tape!
Exhaust leak was determined to be between the cat and the exhuast, gasket replaced!
But as for the brakes... there were signs of the brake master cylinder leaking fluid into the booster... so after replacing the brake master cylinder the brakes felt a lot better, but still not where I would like them to be, i've determined the brake booster would need replacing as well, since brake fluid was leaking into the booster, the diaphram inside the booster was probably damaged. However no one locally seemed to have an extra booster lying around, so I had to wait until someone on club4ag would sell me one.
Non-Sunroof
AE111 20V Blacktop
T3 Velocity Stacks
Cusco Catch Can
Haltech E6X
HKS(?) Exhaust
Hiflow Cat
Greddy Coil Overs
KAAZ 2-Way LSD
Last edited by FujiwaraEightSix on Tue Jan 22, 2013 2:34 am, edited 1 time in total.
-Rick Cunanan
Re: Red Coupe Rebirth
My wiper arms were rusting and looking unhealthy, so I decided to give them a nice coat of black spray paint.
And the previous owner had one of those JDM Bubble shift knobs =/ not my style...
... so i replaced it with one I found in the glove compartment :thumbup:
I also picked up a manual rack setup from my buddy Eric. Probably going to put it as soon as I get the T3 bushing adapter thingy from Gabe @ T3.
-Rick Cunanan
I should be getting my brand used brake booster in soon, so I got the car ready for it...
Also noticed that the clutch and brake pedal brackets were getting really rusty, so i decided i'd pull them out, get them sand blasted and paint those as well. It would be pretty bad if one were to break while driving...
And then I also noticed the clutch master cylinder was leaking.
-Rick Cunanan
So I finally picked up my clutch and brake pedal brackets from my friend, he's had them finished for a while now but I've been busy with other things...
Here's how they look after sandblasting, no they are not primered, that is how they look RAW!
After some black spray paint and an overnight dry, here's them assembled and ready to go in.
The brakes also work WONDERFUL, the new booster seemed to be the "cure all" problems piece.
Also put in the new clutch master cylinder, brand new AISIN unit from PASS.
Here's a video of the engine running...
http://www.youtube.com/watch?v=uFpUpdoYtzk
-Rick Cunanan
The bushing adapter from T3 arrived so unlike my usual self I decided to install the manual rack right away.
Check out the sweet instructions...
It was really easy since the previous owner had the lines looped. Some of them were still in the way but a die grinder and a cutting wheel solved that really fast.
Well it WOULD've been easy but the techno pro spirits/club4ag header get in the way of removing the rack, so I had to remove the header first. This is not necessary if you have the stock manifold or TRD Header 4-2-1/4-1.
Most people have a hard time taking the intermediate shaft out, I had a real hard time with my previous car, so I tried the slide hammer technique which worked out really well, only took about a minute.
When putting the supra intermediate shaft in you should slide it so that 115-118mm of the upper portion is sticking out. Refer to the picture below, where the caliper is measuring should be 115-118mm. This will allow maximum amount of the shaft to go into the column, be enough length to reach the rack, w/o hitting/binding any part of the u-joint.
Rack installed.
Now I should probably get alignment, but for now I just eyeballed it. If you think you can just pop on your PS rack tie rods without adjusting them you're in for a shocker. After eyeballing, you should bring both tie rods OUT about 3-4mm. This should be good enough to get you driving around until you take it to the alignment shop.
Rack installed.
-Rick Cunanan
FINALLY got rid of the motor set...
Thanks hasport for buying the haltech setup!
Thanks balmo for buying the rest of the stuff!
The afternnoon started slowing down at work, so I was able to pull everything out...
Yes, I use the automotive lift to pull the engine out! :thumbup: :thumbup:
-Rick Cunanan
Today some of my goodies came in. Thanks to PASS for everything.
-Rick Cunanan
Originally these were supposed to come friday, according to FedEx.com, however they felt like not being lazy and it came TODAY! I'll admit, i was shaking while opening/inspecting the items. :thumbup: :thumbup:
BIG UPS to RHDJAPAN.COM, absolutely GREAT customer service, top notch packaging/shipping procedures... it's was really an awesome experience ordering from them, needless to say I HIGHLY recommend you go through them!
-Rick Cunanan
In the past I've driven the standard 4AG Bluetop, even tried a Hicomp 4AG, then onto a 150HP 4AGZE! The sadness is these engines are old and tired, and without the know how/money, they cannot be competitive w/o sacraficing reliability. Plus finding parts for these engines is not becoming easier.
AND, I really REALLY REALLY HATE the T-50 Transmission. It's the worst transmission in the entire universe. Shortly after the big bang, as the elements began to cool down, some grouped together to form the T-50 Transmission. Unfortunately for us these were the weakest of all the elements. Now some may argue use the W trans... but IMO that tranny is still OLD and is probably on its way to becoming as sh*tty as the T-50. =P
So here is my engine choice:
F22C from a 2005 Honda S2000
AND on wednesday the shop called and my wheels came in!!!!!!
BIG THANKS to John over at JSP Fab for doing the swap!!!!
-Rick Cunanan
Started pulling of the front end to see how everything would line up/fit.
Also needed to wire up the Levin lights so i needed everything in place to see how long i needed to run the wire.
It's going to take some body work to get everything to fit nice and tight, so i'll leave that for the body shop to take care of.
Bumper/Fender lights work perfectly (at least the way I want them to work)
Its the best I could do with what I have at the shop, i would ideally want to use a real connector to the fender lamps (since it's the same as cigarette lighter plug) but these will do for now.
Christmas be DRAINING my money... so probably no updates till next month/next year =( :thumbdown: :thumbdown:
Have safe and Merry Christmas/Happy Holidays! :thumbup: :thumbup:
-Rick Cunanan
-Rick Cunanan
My tires came in from TireRack.com =)
I went with the Dunlop Direzza Sport Z1 195-50-15
In the past I've used the Dunlop Direzza DZ101 195-50-15 for my fronts, but after the last event I think they might be better for the rear what with the added power.
Loaded up Kristen's EK hatch to get the tires mounted.
Came out good.
Came out good.
-Rick Cunanan
So I got it painted and picked her up at the body shop yesterday.
Today I got to work installing:
-Rear UEO Strut Bar (worst strut bar EVER)
-Wheels
-Uh some other stuff i forget already
Still have to install:
-New door handles
-New locks
-Seat (FINALLY!)
The pics are whack... point n shoot what do you want.
I'm happy.
-Wheels
-New door handles
-New locks
-Seat (FINALLY!)
I'm happy.
-Rick Cunanan
At the last event (towards the end of the day) my car was smoking a lot from the tailpipe. At first I thought it was maybe because I wasn't running an oil catch can... and at the prior event it was smoking a bit too, but I never thought anything of it...
So after I brought it back at the shop I let her chill for a couple days, LOL, didn't want to deal with it. Then I finally got out the compression tester (after warming up the car) and did a compression test. Number 2 Cylinder was low, and after adding oil to that cylinder, the compression shot up. Bad rings... SUCKS.
So I had to get a new engine, SUCKS. I picked up this 2006 f22 with low mileage. I thought it would be pretty straight forward, just change the intake manifold (since 06 is when they went DBW). I was wrong, had to change the intake manifold, valve cover, and front cover.
The shop looks so messy...
Some random s2000 stuff, notice Mr. Johns SUPERIOR welds on the oil pan.
Like I said, had to change the front cover. Why? CKP is different.
Tranny chillin.
Engine is all put together and ready, just letting the oil pan gasket cure.
Old engine, one day i'll rebuild it... LOL but then again I've been saying that with all the 4AGs i had laying around...=P
Tranny chillin.
-Rick Cunanan
So I finally gave in and got a set of foglights...
Thanks Cabe Toyota!
Used the stock harness to wire them up, the part that goes to the USDM fender lamps.
[url=http://smg.photobucket.com/albums/v226/stock86/New%20Red%20Coupe%20Build/?action=view¤t=100_0086.jpg][/url]
I unpinned the connector, in case I needed to convert it back to stock (hey you never know)
Ran some new wire, was able to fit it snuggly into the female connectors (no pun intended LOL) and wrapped it with heat shrink. Then topped it all off with some black electrical wiring loom.
:thumbup:
Now decided whether or not to get a grille... :crook:
Thanks Cabe Toyota!
:thumbup:
-Rick Cunanan
5-5-11
Attended Sonoma/Infineon Drift. Fun event, venue/organizers still need to work a bunch of things out but i'm sure they'll get things going smoothly.
Here's some pics of the cage, still not completely done, it was enough for yesterday though. Going to bring it back to the shop for the finishing touches. Next up, TOYOTAFEST/TORC!! :thumbup:
-Rick Cunanan
Here are some pics from the last event. Getting used to the cage took a while... Everything feels so different... Much props to Joey and everyone at Performance Options for sponsoring me this year!
Photography:
Carlo Pelaez
CARLITOTRON Productions
Photography:
Carlo Pelaez
-Rick Cunanan
5-14-2011
Brought the car down to Long Beach for TORC Toyotafest. I had SUCH a great time. partied the night before... stayed at the Queen Mary Hotel (we on a BOAT!) not a bad way to celebrate my birthday!
The venue was really nice, everything was organized really well (you can tell this isn't their first time holding an event like this) The cars were really interesting to look, but the best part was chatting and meeting with all the different owners! I met a guy who was original owner of a 1985 hatchback. Very good times!
I honestly had no intentions of winning anything... my car is far from being "done" up. So when the category for AE86 came, i wasn't surprised when the didn't call my name. BUT i was super surprised when they called my name for Best Work In Progress 1st place!!!!!
Oh well, here's some pics we snapped with our phones... i'll post better pictures later on.
I just want to thank again all my sponsors, Performance Options & Fatlace, you guys are the best! :thumbup: :thumbup:
Next up, Formula D PRO AM (less than 2 weeks!!!!!!)
-Rick Cunanan
...sorry, I lag...
Here are some more pictures from the track day:
And some video:
http://www.youtube.com/watch?v=PK_RfjGRuN0
And some video:
Last edited by FujiwaraEightSix on Thu May 30, 2013 9:44 pm, edited 2 times in total.
-Rick Cunanan
Awesome build! The car looks amazing keep it up!!
Looks great Rick
Amazing build thread, More build pics please! I had a chance to meet you at TORC and instantly became a huge fan of the car and your build!. Im currently building my own F22c 86 and would love to find out more details on your build ( What things you would recommend or warn to stay away from, any issues along the way that sort of thing ) Im still trying to work out a ton of issues with mine, so any info would help!
I think i saw that your turbo now, what kind of rear end are you running? and how did the car change once you went boost? Thanks again man looking forward to your response, definitely hoping my car can be as nice one day!
Keep up the good work and good luck with your 2013 season!
-Alfredo
-Alfredo
kick ass man!!!
1994 4runner (The truck)
still using a stock corolla rear axle, KAAZ 2-way LSD, and 3.7 r&p. It's held up so far.
-Rick Cunanan
Can you do a f22 swap into a 85 gts? I'm from sf, a couple of my friends checked out your sr5 for sale last year. I have most of the parts already
f20 or f22 can fit into any ae86 chassis no problem. Get the mounts of JSP they will save you a lot of time and arn't that much. And as for the wiring I believe HASport can make a plug and play harness for you.
-Rick Cunanan
I love this car!
EPIC! Awesome build dude!
looks sick. What are the wheels/tire sizes combo?
