Fluids
Re: Fluids
Okay here is what I use:
Engine oil: Castrol GTX conventional oil (10W-40)
Engine coolant: Toyota red coolant mixed with distilled water 50/50 (because it matches the color of my car )
Transmission oil: Redline MT-90 (75W-90 GL-4)
Differential oil: Cusco LSD oil (80W-90, it's expensive but I have a Cusco LSD so... I figure might as well)
Did I miss anything? Oh, I get gas at the Fastrac down the road... just 87 octane, and I use Rain-X all season washer fluid.
Oh also, a good point by Zissou. I use the car just for normal driving (although not really a daily driver, my motorcycle is my daily). I probably put ~1000 miles on it in a year?
Re: Fluids
Gas: BP 93 octane for the 3sge redtop
Coolant: Toyota red
Oil: Mobil 1 full synthetic
Transmission fluid: Redline MT-90
Brake fluid: Motul 600
Coolant: Toyota red
Re: Fluids
I feel like mentioning how you use your car would be worthwhile to mention. A car that is getting tracked every other weekend should be using something other than a car that gets driven to a car show every three months.
Re: Fluids
Zissou wrote:I feel like mentioning how you use your car would be worthwhile to mention. A car that is getting tacked every other weekend should be using something other than a car that gets driven to a car show every three months.
Yea good point, updated my post.
Re: Fluids
Zissou wrote:I feel like mentioning how you use your car would be worthwhile to mention. A car that is getting tracked every other weekend should be using something other than a car that gets driven to a car show every three months.
Thanks for pointing that out!
Re: Fluids
Motul all oils motor, trans diff. Simply the best ; distilled water mixed with royal purple ice in radiator. Syn blend dot 3 high performance for street and motul rbf 600 for track.
Thanks,
Brian
Ae86 Ultimate
Master Mechanic and Master of the Custodial Arts
Los Angeles, CA
Brian
Ae86 Ultimate
Los Angeles, CA
Re: Fluids
azndrifter50 wrote:Motul all oils motor, trans diff. Simply the best ; distilled water mixed with royal purple ice in radiator. Syn blend dot 3 high performance for street and motul rbf 600 for track.
Are you running a 16v or 20v? I'm thinking of running motul when I finish my swap. I'm just concerned about proper operation of the vvt.
Miata people seem to really like running it.
Re: Fluids
16v mild build i change every 5k on 8100 motul oil and wix filter. Its really good it quiets the quirts i noticed it immediately. I tried various brands and motul is one of my favs. I was always the skeptical one till i try then i will have an opinion. I with try amsoil next. And motul i can get cheap if you have cash lol
Thanks,
Brian
Ae86 Ultimate
Los Angeles, CA
Brian
Ae86 Ultimate
Los Angeles, CA
