What did you do to your car today?
Be nice to others.
ae86714
Re: What did you do to your car today?
Postby ae86714 » Sun Feb 22, 2015 9:34 pm
Cut out some patterns of this insulation stuff, I don't think it will do much for sound but I have high hopes for it helping with the heat. Only had time for a mock up:
racer555
Postby racer555 » Sat Feb 28, 2015 12:07 pm
Installed my exhaust today
Pretty damn loud, the rear silencer thing was missing from the box... Got another one coming so it won't be too bad since its my daily
Gino1X1
Postby Gino1X1 » Wed Mar 04, 2015 4:34 am
Just washed my wife's Camry... and guess what.... it rained!
Untill next week!!! <sheesh>
mideng
Postby mideng » Wed Mar 18, 2015 2:25 pm
Drovby gardens and a hoodrat rub my knob....
She said she loved cumrollas! Hoodrats rule
hachi-6 D0ri
Postby hachi-6 D0ri » Sat Mar 21, 2015 8:39 am
spent to much money on it today..and yesterday ....and i will probably tomorrow
If your not crashing .. Stop being a p**$y Go hard in the paint!
~Stig
AKCowboy
Postby AKCowboy » Sat Mar 28, 2015 7:23 pm
Well today i finally made my Levin "Legal" and also installed my new NRG Quick release/steering wheel.
Good Day :)
ritz
Postby ritz » Wed Apr 01, 2015 8:11 pm
Slap different wheels on last week
Jimmee1990
Postby Jimmee1990 » Sun Apr 12, 2015 5:46 am
Drove it for the first time in nearly a year. Loving having a lot more power now too, 282 cams running perfectly on the standard MAP ECU.
norbertopy
Postby norbertopy » Wed Apr 15, 2015 1:11 pm
i buy hin a TRD shift knob
ejmr20
Postby ejmr20 » Sat Apr 18, 2015 11:34 pm
Wrapped up kouki bumper install, hks sport exhaust install, nrg hub modified for proper signal cancellation, and looking at the hack job wiring I did for proper turn signal operation :o . Managed to take her out to 86 nights meet at Longo Toyota dealership :D
85 GTS Coupe
07 Sti RIP
HingaSPL
Postby HingaSPL » Sat May 02, 2015 6:18 am
Woke my baby from her long slumber, My buddy figured out my wiring problem, I changed her worn alternator belt n washed her. Charge light came on, on the way home. Will figure it out Monday when I'm off
lonelywanderer
Postby lonelywanderer » Sat May 02, 2015 11:23 pm
Got my a/c working in time for summer and fixed my cel problem
Grant
Postby Grant » Sun May 03, 2015 8:17 am
lonelywanderer wrote:Got my a/c working in time for summer and fixed my cel problem
What was wrong with your A/C? Need to get mine tested/charged too...
lonelywanderer
Postby lonelywanderer » Mon May 04, 2015 8:16 pm
Grant wrote:What was wrong with your A/C? Need to get mine tested/charged too...
Car just sat for 10 or so years and the r12 was really low so converted it over to r134a.
Grant
Postby Grant » Tue May 05, 2015 6:03 pm
Nice! Did you replace all the o-rings, or just evac and recharge?
I'm thinking of charging with R12A (very different from R12) since it's supposed to be better for original R12 systems.
lonelywanderer
Postby lonelywanderer » Wed May 06, 2015 12:02 am
changed the o rings in the engine bay along with the reciever drier. then evac and charged
-zenki-
Postby -zenki- » Mon May 25, 2015 11:03 am
Soldered a new h4 plug on for the left headlight and fixed some crappy wiring.
FLAWLESS VICTORY
s3cf
Postby s3cf » Tue May 26, 2015 9:41 am
changed the shifter bushing
ejmr20
Postby ejmr20 » Wed May 27, 2015 1:43 am
Finally got my intake installed
85 GTS Coupe
07 Sti RIP
Jimmee1990
Postby Jimmee1990 » Wed May 27, 2015 3:24 am
Swapped my RunFree front bumper over to Zenki Levin to make it a little more street friendly, and cleaned up the new 14x7's and bolted them on.
-zenki-
Postby -zenki- » Sun May 31, 2015 2:30 pm
Spend the weekend cleaning the enginebay. What did i get myself into... Probably hasn't been cleaned in 20+ years. Dodgy repairs and grime everywhere. Also my distribitor o-ring is leaking so there's oilspray on everything.
FLAWLESS VICTORY
-zenki-
Postby -zenki- » Sat Jun 13, 2015 11:29 am
About halfway through my distributor rebuilt. Got 2 new seals on, drilled out the little pin in the shaft/gear. Still have to get a bearingpuller to get the bearing out and replace the inner seal.
Finished most of the enginebay cleanup and retaped alot of the wiring in wiring loom cloth tape.
FLAWLESS VICTORY
saiGone
Postby saiGone » Mon Jun 15, 2015 8:17 am
Fixed the timing with a cheapo Harbor Freight timing light.
Finally pulls strong!
dellaVeritas
Postby dellaVeritas » Tue Jun 16, 2015 8:43 pm
Started working on my bent strut casing
shadowwolf151
Postby shadowwolf151 » Wed Jun 24, 2015 7:19 pm
Didn't do it today, It was a few weeks ago while I was back home on leave. Replaced the busted P/S rack with a re-manufactured one, inner and outer tie rods, tape measure front alignment (totally nailed it, drives perfectly straight), finally fixed the shotty wiring job the previous owner did for the amps and speakers he put it, (BTW there is no reason to have 4 6x9 in the back window, and 2 6" speakers in the back seat side panels), replaced driver and passenger door panels with some clean ones I bought on FB, (again, previous owner decided to paint the old one black with oil based paint, so it ran, dripped, and melted in the heat), and replaced both front seat-belts with universal 3-point replacements, all in one day. This car need a lot of TLC, and I still have a ways to go, but it will be worth it in the end :D
alavelle12
Postby alavelle12 » Sat Jun 27, 2015 1:31 pm
Still in tear down mode for my 20v swap. Worked on pulling the rest of the heater box and everything under the dash (I'm going to be running just a half dash with no heat/ac). Also pulled the old 4ac broken cruise control and power steering lines. Still trying to decide if i'm going to b uy a manual rack or just loop the lines on my ps rack. Been working on cleaning up the engine bay with simple green as well, works amazingly! Trying to decide what color I want to paint my bay/stripped interior. Thinking a darker grey..
zem
Postby zem » Sat Jul 04, 2015 12:12 am
cleaned engine bay, alternator went out... :(
#savethe86
Demented86
Postby Demented86 » Sun Jul 05, 2015 4:45 pm
I kicked the clutch.. ;)
"Life's simple. You make choices, and you don't look back."
ejmr20
Postby ejmr20 » Mon Jul 27, 2015 10:37 pm
Finally got some brackets to mount my license plate on my kouki bumper Image[/URL]
85 GTS Coupe
07 Sti RIP
ritz
Postby ritz » Tue Jul 28, 2015 8:23 am
ejmr20 wrote:Finally got some brackets to mount my license plate on my kouki bumper Image[/URL]
NICE!!! I just ended up drilling mine. Where did you get them?
Installed intake.
Return to “Fun Talk”
