WTB: Speedo Cable_GTS_Manual
mideng
Postby mideng » Sat Dec 24, 2016 12:13 pm
Looking for speedo cable....for manual gts....if that matters
thank you
CloudStrife
Re: WTB: Speedo Cable_GTS_Manual
Postby CloudStrife » Thu Jan 05, 2017 11:33 am
Make sure you get the GT-S speedo gear on the cable. There is a difference between the speedo gears between the GT-S and the SR5. One has 16 teeth and the other 20. If you're getting a full speedo cable with the gear (can't remember if these corollas use a single cable), make sure it says 16 and not 20. Pretty sure I have that right.
Here is a cable on Ebay for 40.00:
http://www.ebay.com/itm/Toyota-Corolla- ... q~&vxp=mtr
And you can buy the speedo gear new from Japan:
http://www.ebay.com/itm/T50-SPEEDO-GEAR ... Yg&vxp=mtr
Around 80 isn't too bad, and it's a good idea to replace that gear. Usually OEM cables are more expensive.
Good luck!
Unknone86
Postby Unknone86 » Mon Jan 09, 2017 8:00 pm
I have that same one that I did not use because I never got around to rebuilding my tranny and will sell it for 30 depending on shipping wanted. Its for the GTS. Where are you located?
Return to “Want to BUY (seeking sellers)”
