Socal: 85 gts parting out
cerumo
Postby cerumo » Tue Jul 18, 2017 12:15 am
Parting out a Gts and Selling Spare parts I've been hoarding over the years. Ask for anything I did not post, and I'll see if I have it. I Will post more parts. Running GTS hatch parting out parts with low mileage on rebuild.
Prefer text to 626 536 0066
Sold Kouki LSD differential assembly, including cables and calipers
400 GTS transmission each
250 SR5 transmission without bell housing
400 GTS Fuel line and gas tank
450 JDM Zenki bumper
500 Brand New HKS Sport exhaust
400 Used HKS Sport exhaust
350 Brand new OEM GTS cat back exahaust
275 GTS after market system
800 Brand New Apexi Hybrid Megaphone exhaust
250 1985 GTS Hatch under dash harness
250 1985 GTS Hatch engine bay harness
200 1985 GTS Rear Hatch harness
250 OEM gts header and downpipe
150 OEM down pipe with after market cat
500 JIC adjustable coilovers with spindles
600 Brand New Fortune Auto 500 rears adjustable high spring and shocks. Drove for 50 miles and took them off.
2000 Rebuild hi-comp long block with .5 oversized stock pistons,new oil pump, blue top cams, bronze guilds, upgraded springs, decked block and head, .08 TRD head gasket. It does not come with accessory. Compression test more than 210 psi on each cylinder.
1000 Resurfaced and rebuild 4age 16v head with brand new Tomei 268 exhaust and intake cams.
300 water line assembly
100 Red top injectors
150 250 cc injector for oem harness with Hi comp motor
250 Megan rear shocks
800 Good condition OEM side skirts with oem end caps
700 TRD 4-1 header
200 HKS Cams gear
Sold Silk Road header 4-2-1 with adapter for LHD vehicle to work with manual steering rack
2500 GTS Zenki rear differential Assembly, used for 1000 miles with all new 4.3 ring and Pinion, new bearings, new Tomei 1.5 way lsd, new Oem brake pads, New Brake cables and Re-manufactured brake calipers and new Goodrich Braid brake lines
700 Rebuilded GTS transmission with new Seals and Syn chros rings.
400 Brian Crower 280 exhaust and intake cams
350 500 miles resurfaced light weight oem black top 20v flywheels and exedy clutch.
200 Shaved front fenders
150 Gts Hood
300 Completed 1986 front bumpers assembly with Grill.
200 Silver Headlight assembly
600 Konig Rewind 14x7 -9 with new tires
250 Celica Supra wheels
350 Zenki Gts front seats
200 GTS rear seat
300 Zenki Gts doors panels
350 Zenki engine harness
100 Auto side mirrors
150 Front seat belts
100 Rear seat belts
150 rebuild distributor
150 Intake manifold assembly
150 Gts K&N intake
150 Injen intake
150 Good working mass air flow meter with intake tube
150 Igniter with new MSD Blaster 2
80 brake booster
100 GTS Door
200 Front and rear carpets
150 AE86 cracked dash
400 Rebuild manual rack with new inner and outer tie rods
250 Rebuild manual rack
150 manual u joint and shaft
150 Ae86 Steering column with key
200 Gts hatch rear wing
150 TRD Engine mounts
100 Speedo cable
150 New Aisin cluch slave and new TRD clutch line
100 GTS clutch hardline
80 Aisin clutch master
https://losangeles.craigslist.org/lac/c ... 12716.html
