FS: '95 Corolla 4AGE 20V complete or part-out
Posted: Fri Feb 24, 2017 7:24 am
by rickrolla7
PAYMENT PREFERENCE: CAD, Paypal, possibility to ship internationally
ITEM: Complete car or Part-Out (most parts fit 1993-2002)
PRICE: $4500 complete car or TBD for part-out
DESCRIPTION: 1995 AE101 Toyota Corolla Base
Body Mileage : 219000 kms
Mileage Since Rebuild/Modifications : Less than 500 kms
Engine : Fully Rebuilt 1,6L 4-Cylinder 4AGE 20-Valve « SilverTop » with adapted harness and ECU
Transmission : Fully Rebuilt 5-Speed manual
Options : - Manual doors
•Manual windows
•Remote starter
•Gauge cluster w/ RPM
•No A/C
•Very little rust
Engine Rebuild : - Full engine wash and de-carbonizing
•Repainted block, valve cover, timing belt cover and intake cover
•All new seals
•TRD head gasket
•New OEM Toyota spark plugs, wires, distributor cap and rotor
•TODA high performance timing-belt
•New OEM Toyota water pump
•New OEM Toyota oil pump
•New OEM Toyota crank main bearings and connecting rod bearings
•Cylinders sleeved and pistons with new Original Toyota rings
•A/C compressor delete
•All new ARP bolts, nuts, studs
Transmission Rebuild : - New synchros
•All new seals
•New axle shafts
•Brass shifter cable bushings
•New master and slave cylinder
Other Mechanical Rebuild (all OEM Toyota Parts) : - Fuel tank, straps, filler neck, pump, & filter
•All new fuel and brake lines
•2 new subframes
•New front lower tables, ball joints, swaybar link kits
•New front knuckles, hubs and bearings
•New steering rack, high and low pressure lines
•New rear suspension arms and swaybar links
•New radiator
•New front calipers, proportioning valve and master cylinder
•New engine and transmission mounts
Upgrades and Modifications : - Konig Helium bronze 16 in wheels 4x100
•205/45R16 Bridgestone Potenza RE960
•Excedy lightweight flywheel and stage-2 clutch
•Performance intake and filter
•Hi-flow Magnaflow Catalytic converter
•Tanabe Hyper Tuner Medalion
•2,25 in exhaust
•Strut-tower brace
•Tokico HP struts
•Suspension Techniques 1,5 in lowering springs
•Tein adjustable Pillowball upper mounts (top plates)
•Hotchkis front and rear adjustable swaybars
•TRD short-shifter
•MOMO carbon fiber and leather steering wheel
•Pioneer CD/AM/FM/MP3 head unit
•Orion 10 in subwoofer with enclosure
•Infinity Audio rear deck 3-way speakers
•Yonaka front racing seats
•TRD aluminum pedals
•Hawk brake pads
•M-Sport front drilled and slotted rotors
•Rear AE101 disc brake conversion with rebuilt calipers
•Project 'u' slotted rear discs
•Goodridge stainless steel braided brake lines
•Removed all logos
•Tinted taillights
•Tinted windows
•Clear front side markers and flashers
•Xenon-bulb headlights
•Handmade front grille and real facia
Re: FS: '95 Corolla 4AGE 20V complete or part-out
Posted: Sat Feb 25, 2017 6:00 pm
by jondee86
Hiya... you might like to try uploading your pics to an image hosting site like Photobucket
and then copy/paste the {IMG]blablabla...[/IMG] links back here with your post.
Cheers.... jondee86
Posted: Thu Apr 20, 2017 9:35 am
by plaidward
Use this site, it's free.
