TX: FS: 86 GTS Rolling Shell w/ CelicaSupra rearend, RX7 brakes +++
jpaint86
Postby jpaint86 » Sat Sep 03, 2016 5:14 pm
Waco, TX I do have a trailer and can deliver to a certain extent $$
Selling my clean title true gts 86 Toyota corolla. I did a 1uz motor swap but sold the motor swap. The subframe is modified to bolt straight to 1uz.
Aluminum radiator / electric fans, relocated oil filter, oil cooler
Celica supra rear end, new bearings w/ welded diff solid pinion spacer
Suspension:
Front custom coilovers w/ 8k springs, newer struts, tein camber plates
T3 knuckles, T3 NCRCA, Megan tension rods, Factory swaybar w/ new end links, Poly control arm bushings
Manual steering rack with Quaife quick response kit, power steering tie rod ends
T3 5k rear coilovers, ST rear swaybar, adjustable 4 links, T3 Panhard bar, T3 traction brackets
Brakes:
RX7 front brake kit with drilled / slotted rotors, ss lines
Drilled / slotted rear rotors with new celica supra calipers, ss lines
300zx Master Cylinder
ISIS handbrake w/ SS lines
Everything else:
T3 Hatch bar, custom rear strut brace
I stripped interior and engine bay, spot welded all seams, primed and painted inside white and engine bay metallic purple
Fiberglass fender flairs molded to the car
Front wheels are Rota's 15x9.5 with new 205/50 Nitto NeoGen, Rear are Basset Steelies 15x10 with new Kuhmo 225/50
New gas tank (not installed yet)
Oil pressure and water temp gauges
NEW DRIVER DOOR HINGES!!!!!!
Body is in pretty good shape there is a little more to do before it's 100% ready for paint. Windshield is cracked but rest of glass is intact.
I drove the car with current suspension/steering setup for about 100 miles before the swap, it felt awesome just needed some power behind it.
asking $2600
Can DM, email jpaint123@gmail.com or text me 423741556one
Clean Title I have a lot of time and money tied up in the car and want to keep it but will be happier not sitting in storage.
When motor was in:
jpaint86
Re: TX: FS: 86 GTS Rolling Shell w/ CelicaSupra rearend, RX7 brakes +++
Postby jpaint86 » Thu Sep 29, 2016 7:42 am
Thursday Bump OBO
jpaint86
Postby jpaint86 » Tue Jan 17, 2017 6:55 am
Price drop bump
jpaint86
Postby jpaint86 » Mon Feb 06, 2017 9:12 am
Monday Bump
